Ed’s 85 VF700F
Discussion in '1st & 2nd Generation 1983-1989' started by Ribrickulous, Dec 17, 2021.
    Do yourself a favor right now and order the next size up pilot jets too.
    #61
  2. Jim McCulloch
    Jim McCulloch Member
    Great post going on here. Good learning for the next time I screw up and buy a 1st gen V-4!
    #62
    squirrelman likes this.
  3. squirrelman
    wow. those carbs appear unusually filthy !
    somebody didn't bother to read the FSM, as carb removal instructions do not suggest removing the plenum while carbs are in place on the bike, why the tube broke.
    if you know how to do the blow test to check the health of the slide diaphragms, i'd suggest, if they are good and move up and down nicely, not to remove the top cap as no dirt gets in there, and you might have hours of grief trying to get the shrunken rubber back in the grooves properly. hours of grief. if you need to resort to "stickum," the diaphragms will likely be damaged upon any later removal.
    #63
  4. Ribrickulous
    Ribrickulous New Member
    Lol!
    Capt - did drill the pilot plugs and pull/clean/etc - it wasn’t bad at all, good call.
    Found a lot of blocked emulsion tubes, all bunked with varnish behind the jet itself. Most of the floats were 1mm off in one direction or another.
    Now just trying to figure out where these two springs should be. Seemed like they fell off when I was fiddling with the carb in front right - the one with the throttle plate:
    -Ed
    1972 CL350
    1985 VF700F
    #64
  5. squirrelman
    small one goes between throttle interconnections for synch , larger one goes between carbs.
    #65
  6. Ribrickulous
    Ok - yes, found the missing throttle interconnect - getting all those back together is going to be a pain.
    It’s unclear from the manual picture where the two larger ones go (found the second off to the side).
    And yes - the manual does not tell you to take the airbox off. For some reason I went into autopilot and am now paying the price.
    Re: vacuum piston rubbers, honesty they went back without an issue. I used a little dab of grease to hold them in place against the carb body like I did with my 350 carbs.
    -Ed
    1972 CL350
    1985 VF700F
    #66
  7. sixdog
    sixdog Insider
    Excellent… remember Ed the install goes with the plenum on. I should have reminded you earlier… sorry brother.
    #67
  8. Ribrickulous
    Looking much cleaner inside and out
    -Ed
    1972 CL350
    1985 VF700F
    #68
    Jim McCulloch and sixdog like this.
  9. Ribrickulous
    My fault for reading more of the manual than is actually there ‍
    -Ed
    1972 CL350
    1985 VF700F
    #69
  10. squirrelman
    Nice Work !
    how did you clean them ?
    #70
  11. Ribrickulous
    Old fashioned way - tub of ZEP (general cleaner/degreaser) with a soft nylon brush after all the brass was removed, then deluged with water, blew it dry, carb cleaner in all the passages and brass, compressed air all that dry.
    Hardest thing used was probably the nylon brush or the nylon pipe cleaner - no hard wires and all the gunk is out. Ignore the K&L carb cleaner on the bench - I took it out then thought better of it
    Old place had an ultrasonic AND a parts washer that I would’ve loved right now, but whattya do.
    -Ed
    1972 CL350
    1985 VF700F
    #71
  12. squirrelman
    after any deep soak you need to lube the throttle shafts or risk them seizing up during a storage period.
    #72
  13. Ribrickulous
    Yes - that was done. I’m not sure what others like but I use this stuff religiously:
    https://www.amazon.com/Tri-Flow-Squ...ocphy=1022762&hvtargid=pla-315876899021&psc=1
    They make it in a spray bottle too, but it gets everywhere.
    It’s got liquid Teflon in it. I used it on the throttle shafts and choke shafts, as well as a *light* coat around the vacuum pistons to get them moving. It’s my go-to cable lube also.
    Doesn’t hurt that it smells like bananas in like a chemically-but-pleasant-banana kind of way.
    -Ed
    1972 CL350
    1985 VF700F
    #73
  14. squirrelman
    dija ?
    and
    #74
  15. Ribrickulous
    Huh?
    -Ed
    1972 CL350
    1985 VF700F
    #75
  16. Colddevil
    Colddevil Member
    Wisconsin
    I think the Squirrel'd one wants to know that you strung your carburetor jets up like a guitar. err... that you ran a guitar string or something similar through the orifices to verify that they are clear. I use fishing line since I've never actually remembered to snag some guitar string from anyone.
    #76
  17. Ribrickulous
    Ah.
    I did not - put them up to light, saw light. Sprayed cleaner in one end, it came out the other.
    All the rest of the gunk in there disintegrated with some carb cleaner.
    -Ed
    1972 CL350
    1985 VF700F
    #77
  18. squirrelman
    merely seeing a peek of light is not the same as verifying that the hole is FULLY open with a .010"-.012" guitar string .
    i' ve seen many jets that showed some light but were not FULLY clear until they were poked with a wire, physical cleaning not just chemical carb spray.
    #78
  19. Captain 80s
    Take an old cable, any old cable. Cut one end off and pull out the twisted cable from the sheath. Now cut about 12 inches off. Remove one strand from the cable. You just created the perfect jet cleaner. It has curls in it, so when you run the jet up and down on it, you know the wire is touching the sides of the jet and cleaning it. Finish with carb clean and compressed air. Win.
    #79
  20. Ribrickulous
    Ehhhhh I’ve always steered clear of metal stuff in the jets. They’re miles better than they were - I feel good about them.
    Just waiting on the SS tubes and those tiny little cotter pins that hold the linkages and we’re back in business.
    -Ed
    1972 CL350
    1985 VF700F
    #80
