Electrical problems?!?!?!
Discussion in 'Mechanics Garage' started by tonette369, Jan 31, 2009.
  1. tonette369
    tonette369 New Member
    I have a 95 VFR with about 40K mi on it. Two weeks ago about 5 mi from the house, after only riding about 25 mi, the bike died on the highway. Jumped it off and got it home. Went and got a new battery, Sears Die Hard, and installed it. Today after about 30 mi the bike dies again. I was close to a friends house so it is sitting in their garage now. Does this sound like the stator is shot and not charging back to the battery?
  2. steven113
    steven113 New Member
    Pensacola FL
    More than likely it is your regulator/rectifier refered to as R/R. It could also be wire connections to it. Check all connectors for corrosion and your harness for possible fraied spots(shorts). Put a good solid overnight charge on the battery and see if the problem is gone. If it still occurs I would look into the output of the stator, a honda service manual should have instructions on what readings you should get with a meter while testing.
  3. malcster
    malcster New Member
    Bishop,CA USA
    It's not the batt.. sounds RR as per Steve.Common problem,lots of info,archival, on this subject for your gen.good luck.
  4. squirrelman
    the easiest, quickest check is to put a voltmeter across the battery terminals with engine running at about 5k rpm.....
    you should have about 13.5 volts.
  5. Maggot
    Maggot New Member
    Park Ridge, IL
    Go to Yuasa Batteries, Inc. for everything you ever wanted to know about testing and charging batteries. Click on literature then click on Yuasa technical manual.
  6. malcster
    malcster New Member
    Bishop,CA USA
    Oh shit'so fucked from those x-games
