Hey there fellow Aus Viffers I'm after a bit of info. I have a 1986 VFR750fg and am looking for the plate/plug that screws into the right side engine cover. It covers the cam timing marks. I am restoring this bike including an engine strip. This was my first step in pulling the engine apart and found someone had butchered the hex on this cover. I had to basically destroy the cover to remove it. Anyone know if they are still available from Honda of any good places in Aus to find one? Thanks for any help in advance. Cheers
Try Mr Motorcycles in St Agnes, South Australia. I have recently seen a fire damaged VFR of the right model in his yard. No idea if he'll separate the part you want but it should be useable if you can get it. Ph is (08) 8263 3341.
