Engine failure
Discussion in '1st & 2nd Generation 1983-1989' started by Wands434, Aug 15, 2016.
  1. Wands434
    Wands434 New Member
    Syracuse NY
    I'm just about to pull the motor now. Few more bolts
    #41
  2. NormK
    NormK New Member
    Can you shoehorn a later 700/750 into the 500 frame
    #42
  3. Wands434
    Wands434 New Member
    Syracuse NY
    I wish I could but I do believe the 700/750 is a lot wider.
    [​IMG][​IMG]
    #43
  4. Wands434
    Wands434 New Member
    Syracuse NY
    Honestly this 500 is shoehorned in there... What a pain to get out. Wish the other side of the frame was removable too
    #44
  5. Wands434
    Wands434 New Member
    Syracuse NY
    Update:
    Driving home with new motor. Check these guys out on eBay. Paid 400 cash for motor. He jacked price up on eBay to hold it for me. Class A shop many vintage parts
    Also he had a vr 250 motor. It caught my interest. Would be cool as a little project is this literally a split in half 500 motor
    [​IMG][​IMG]
    Are parts harder to find than the 500
    #45
  6. Wands434
    Wands434 New Member
    Syracuse NY
    Even gave me a handful of other 500 parts for cheap I cleaned him out
    #46
  7. ridervfr
    Sounds like Nirvana, teenage spirit? Nice write up, keep up the good work :thumbsup:
    #47
  8. Wands434
    Wands434 New Member
    Syracuse NY
    After stoping at a old navy buddies house that put me behind. [​IMG]I'm ready to pull a all nighter
    #48
  9. Wands434
    Wands434 New Member
    Syracuse NY
    I have been so slammed by work I have just had time to get back to work. Should be riding again soon enough.
    [​IMG][​IMG][​IMG][​IMG]
    #49
  10. Hellapet
    Hellapet New Member
    Media, PA
    prettyyyy. nice to see you'll be back on the road just in time for the wet weather to kick in. did you do a valve adjustment while you were in there? if so, how hard was it?
    #50
  11. Wands434
    Wands434 New Member
    Syracuse NY
    Honestly I did not. The motor is bone dry I didn't want to be rotating it around. I think I'm going to pull it all apart again this winter and start powder coating everything. I don't have many days left until end of season but I will ride until snow flys. I am going to take it much easier on the old girl.
    #51
  12. Hellapet
    Hellapet New Member
    Media, PA
    supposedly if you stay below 10000rpm you can make these engines last a while. I'm sure that it can wait til winter to do the valves though.
    #52
  13. Wands434
    Wands434 New Member
    Syracuse NY
    It was a running motor with video from cold start. And I picked up a bore scope and I looked inside all good. But after it fires 1-2x from cold if it needs a adjustment you should hear it.
    #53
  14. Wands434
    Wands434 New Member
    Syracuse NY
    So a few things happened today. First off trying to connect fuel line I dropped the tank and dented/ scratched it. I'm very upset.
    [​IMG][​IMG]
    But I got it to fire. All good at first. 1200rpm
    https://vimeo.com/185243360
    I noticed that it was not as snappy as before. Very slow to rev and come back down.
    https://vimeo.com/185243625
    #54
  15. Wands434
    Wands434 New Member
    Syracuse NY
    https://vimeo.com/185244191
    And the rpm climbed to 5k. Then started rolling some gross smelling smoke.
    It smoked at fire up. The plugs where wet with oil. Must have been from tilting one side to other. Initial smoke was no concern. I painted motor then threw fresh plugs in. I'm on call for work this weekend and haven't had a full hour all weekend to mess with it. But now I'm bummed and concerned.
    #55
  16. Wands434
    Wands434 New Member
    Syracuse NY
    I assume the rev is from a air leak. I'm going to re check the carb boots but just as I was going to shut it off I seen some smoke and ran to get my phone.
    So much time and money it's really beating me up. I just wanna ride
    #56
  17. NormK
    NormK New Member
    Engine failure
    86 vf500f
    So I was cruising along, 95mph or so.
    Good to see you have realized some things need to be taken easy
    #57
  18. Hellapet
    Hellapet New Member
    Media, PA
    Sorry to see the new scar. I still stand by the idea that it should be fine at 95mph. maybe im in denial...
    #58
  19. Wands434
    Wands434 New Member
    Syracuse NY
    I'm 50/50. I am going to take it a little easier on her. Not that a beat the crap out of it before but idk. I'm so bummed over the tank. I think I had a harder time putting the fuel line on than I did putting the motor in the bike.
    #59
  20. thx1138
    thx1138 New Member
    Perth
    If smoke does not go away and compression is good, then valve stem seals.
    #60
