Essential tools or equipment you got to have
Discussion in 'Mechanics Garage' started by dABIT, Dec 17, 2016.
  1. NorcalBoy
    I guess you could use it and muck around with it. Supporting the frame by the subframe is the factory recommended method, as the cast member where the swingarm and footpegs mount, comes off during the engine removal process. I have done this a few times.
  2. Riding a 2000
    Riding a 2000 Insider
    Rochester Hills, Michigan
    Music Source. XM/Sirius in stereo is my choice, over FM broadcasts. (or, if inclined, an AM talk-show capable radio you can laugh/yell at while working)
  3. zoom-zoom
    zoom-zoom Member
    BC, Canada
    One thing I keep handy whenever I'm working on my bike at the house is an LED headlamp. I've got a couple of inexpensive ones that I purchased at Home Depot. They are very handy whenever you need both hands AND light directly where you're looking.
  4. A.M
    A.M Moderator Staff Member
    Do you have a heat source?
    Working in the cold sux. Fingers don't like to work, hands get beat up, what you are working on/with can be affected.
    I see you are in FL, but still something to think about or if anyone else sees this thread and needs ideas.
    It's just the only thing I can think of since I know what's it's like to usually wrench in nasty cold.
  5. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    A couple boxes of thin rubber gloves. The 5 mil nitrile at HF are great and less than $6/100. Beats the heck out of digging oily goo out from under your fingernails for a couple days.
  6. DeeBee
    DeeBee New Member
    Fort Ooglethorpe , Ga
    Got to have a good mechanics seat on wheels with a small shelf attached under it.
    The one I use is around 1-1.5 feet tall at the seat and has a similarly sized square shelf about the legs. Not only does this allow you to work on a bike when it's on its center stand( even if the front is lifted a bit) , but also let's you move around while keeping the tools your using close at hand.
    If course if you have a tall lift table with plenty of room on top then a little low roller stool wouldn't help much.
    Another tool I couldn't or wouldn't do without is a small 12-18v lithium battery powered impact. Mine is good for 100-125 ft/lbs and accepts all 1/4" bits and socket adapters. I usually have a 3/8" square bit attached so that I can use 3/8" sockets and Allen sockets.
    Also a decent sized (8mm-17mm at least) ratchet wrench set will make most jobs go quicker/easier.
    Another great thing to have is an assortment of high grade bolts and nuts, the more the better.
    Enjoy your shop/ garage.
  7. JZH
    JZH New Member
    Spain
    Leiden, mostly
    According to his "My Ride" section dABIT's got a 750, so the ABBA swing arm removal kit would work fine without much drama. My FP (that's a '93 VFR750F in new money) is using that combination at the moment, as I'm in the middle of fitting an RC30 swing arm (not a straightforward operation, as it turns out...) and have the swing arm on and off all the time. That said an ABBA makes a nice work stand, but they're not very common in N.America, so probably out of the question anyway.
    Ciao,
