Fender Eliminator kits
Discussion in '6th Generation 2002-2013' started by Zoober, May 21, 2010.
  1. Zoober
    Zoober New Member
    Omaha, NE
    Someone did mention cutting that seciton of plastic off below the license plate, I was thinking of doing this myself, hence why the no-cost delete worked well for me.
    I will suggest however, repainting the bracket though once you have it out, because it will be dirtier than all hell and looks like ass if put back in like that.
  2. gpdesign
    gpdesign New Member
    Lynnwood, WA USA
    Anyone have a 6th gen stock rear fender they want to get rid of?
    I ride in the rain a lot and need one! I also need the license plate light.
    Thanks,
    Greg
  3. afinepoint
    afinepoint New Member
    Henrico, Va. (Short Pump)
    How do you keep the lower clips for the forward most bolts from twisting while removing the bolts? It looks like the clips are held in place with the plastic surround of the fender. As I turn a bolt the entire clip turns tearing the plastic.
    Point
  4. Kobe Diesel
    Kobe Diesel New Member
    CT
    I dont like my fender eliminator (came with bike). I would prefer to modify the orig.
  5. Zoober
    Zoober New Member
    Omaha, NE
    I had to use a socket with a wrench, otherwise tho bolts will twist.
  6. reepo
    reepo New Member
    Anyone know if a Mass plate fits between the exhausts??
  7. stewartj239
    stewartj239 Member
    Syracuse, NY
    Do you know how wide it is or are you asking? If you know the width, I can measure the clearance for you.
  8. afinepoint
    Since the fender is there to deflect debris and dirt how messy do the lights and seat underside become once it is gone? I ride in all weather.
    Reg
  9. NorcalBoy
    1.) Fender elim will not work with factory hard bags
    2.) Some license plates require tweaking to fit
    3.) If you choose to jethro the stock setup, then accept that others find this level of solving the problem ghetto.
    4.) the stock fender does little to block anything with any level of effectiveness
    5.) the undertray is there for a reason
  10. Big3
    Big3 New Member
    Lancaster, Ohio
  11. afinepoint
    Sounds good. Now back to my other problem of figuring out how to still use my Cortech bags.
  12. havcar
    havcar New Member
    Denver CO
    The tail light gets a little dirtier under wet conditions. That's all I've noticed, seat and rear cowl don't get any unusual dirt to speak of. What the eliminator does for aesthetics far outweighs the few extra seconds of maintenence, IMO.
  13. PhatDoggy
    PhatDoggy New Member
    You say that like it matters what others think.
  14. Banderso
    Banderso New Member
    Washington IN
    Hi
    I need a rear fender for an 02-09 VFR
    Anybody got one they will part with?
    thanks
    bill
    ***IN Georgia USA***
