First oil change brings about unknown question......
Discussion in '5th Generation 1998-2001' started by Markvfr800, Apr 19, 2014.
  1. Markvfr800
    Markvfr800 New Member
    :eagerness: hello all, finally got around to changing the oil and filter and coolant on the bike, previous owner said oil was only done but i doubt that-- i had a new genuine filter which i had for the deauville and lucky its the same part! anyway after getting through the fairing minefield(ill need to replace fixings in future) it all went fairly well, ill need to replace oil bolt next time as i overtightened it trying to open it initially ......... anyway my question is in the pics, what is the green thing attached to frame and what is the unconnected electric connection!?
  2. stoshmonster
    stoshmonster New Member
    The Green thing is an ignition coil,not sure what the wire connector plug is for Mark.
    If you can get a good pic of the wire colors in that connector plug I can identify it.
  3. 34468 Randy
    Hope your didn't strip the thread on the plug. Cause it will be the threads on your pan than is more likely to strip than the plug itself. I did the same thing. If you did, there are fixes for that. I think it is something called a heli thread or something like that. I just replaced my pan...the expensive route.
  4. sunofwolf
    sunofwolf New Member
    don't forget to take your carbon canister off and put in closet to save 3 pounds :gun3:and pollute air and easy to change the filter next time to a extra large purculator oil filter-plug one hose going to gas tank-guess which one? Randy how could you be dumb enough to strip your oil pan bolt? Ok, I see, I can fix things better than 99% of you guys even save my plastic with my foot-we all can't be superman
  5. squirrelman
    Cuz Nelson Eddy sang about "strong-hearted men," and they have strong arms too !!
  6. 34468 Randy
    Wasn't hard at all really. I can show you how if you want to learn. That was a truly blond moment for sure. Seems I have those quite frequently.
  7. 34468 Randy
    I think, if my memory serves me, some times it does, sometimes a little less so. I misread my torque wrench settings. I was trying to do this right by reading the book. SHould have read the scale on the wrench more closely.
  8. Markvfr800
    Cheers ill google the shit outa the ignition coil now to see what i can learn/fix/do or improve with it, prob get a better photo of that in couple months when i get chance to strip her down again..........
    absolutely lost you on this one!
  9. Badbilly
    Son of woof occupies the same space as the carbon canister and is randy over Randy.
  10. Badbilly
    First off Randy is a Scotch man as opposed to a Scottsman. Some Canadians do not drink stout or eat oatmeal twice a day even though it makes anyone strong. Some Canadians drink oatmeal stout all day.
    Old movies are great and Nelson Eddy was a great singer but all those dudes looked like they were more like the Village People than sailors. It looks to me like the wardrobe department saved those costumes reusing them in harleydood biker flix.
    https://www.youtube.com/watch?v=1vjqfvZVReM
  11. sunofwolf
    You must have went the wrong way-your suppose to set your socket wrench up to go the right way before you use it. This has nothing to do with being strong-its 20pounds-one more than my car. You put blue loc on so it doesn't come loose
  12. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    Doesn't look like it was answered. That open electrical connector goes to the PAIR valve to open/close it. Your previous owner probably did the PAIR delete.
  13. 34468 Randy
    True. More accurately a Scotch snob.
    Less true. Lots of that blood in my lines
    The Irish are more known for their stout, but I do like my oatmeal
  14. Markvfr800
    just an update on proceedings, iv a couple of photos of wires/parts if anyone could help identify !!
    IMG_20140516_150010.jpg block with brown and green wire, whats it for?
    IMG_20140516_131850.jpg just a pic of my fairings polished ad ready to refit
    IMG_20140516_150035.jpg might be hard to see but of the 3 wires attached through the rectifer fan one is cut
  15. BWeiss
    Rancho Cordova, Ca
    where on the bike is the first pic? by the left hand passenger foot peg?
  16. Markvfr800
    no thats on right side, I didnt have time to trace it to anything, just curioius when I find another unconnected block, figured it might because of PAIR or alarm system mods?
  17. Markvfr800
    Okay so the round hole in the top of air box is basically covered by the foam under the tank, but in front of that there is a cut out, just a square open space, but there is already an air inlet on the right side..... is that normal?
    IMG_20140516_163033.jpg IMG_20140516_163033.jpg better pic
  18. BWeiss
    Rancho Cordova, Ca
    that is where the flapper valve went...P.O. obviously removed it. That is all, no biggie.
  19. Markvfr800
  20. Badbilly
    Better than SOW's diet of puppy chow.
