first project
Discussion in '1st & 2nd Generation 1983-1989' started by MetalMagician, Apr 27, 2013.
  1. MetalMagician
    MetalMagician New Member
    Parkesburg, Pennsylvania, United States
    So I am starting this project to keep me busy. Its a 1986 700. Will be posting pictures and more details soon
  2. ThatVF500Guy
    ThatVF500Guy New Member
    Atlanta, GA
    Welcome. Lot's of good advice here.
    Here's one: get yourself a factory manual.
  3. scubabiker
    scubabiker New Member
    stord, Norway
    I have a similar project. Just ordered new cam chain tensioner and a few other parts. Luckily i work in a motorcycle shop so i get free used parts and trade price for new parts!
  4. MetalMagician
    Factory manual is ordered. I stripped the bike yesterday. Im out of town until maybe Wednesday so ill be on hold for a bit. The bolt on the rear of the motor near the swing arm is stuck. Suggestions to take it out?
  5. scubabiker
    stord, Norway
    Heat and penetrating fluid. Also try with a rattle gun
  6. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Try soaking it for a couple days with PB Blaster and try again with an impact if you have access to one.
  7. ThatVF500Guy
    Atlanta, GA
    +100 on the heat. It's amazing what that will do to rusted, stuck or glued on fasteners.
  8. squirrelman
    Chain tensioner on an '86 VFR ??? Not.
    raeva me verker !
  9. MetalMagician
    Ok ill try that when I get home.
    Does anyone have the intake base? It's the part of the intake that bolts directly on top of the carburators. Come to think of it I need the o rings too.
  10. commrad
    commrad New Member
    Red Hill, GA
    on the swing arm bolt, I've had a couple that not even heat would budge. The Only thing that worked was heat with a brass drift. I have no idea why brass, but it's saved me more than once on a stuck swing arm bolt.
  11. Metallican525
    Rockville, Maryland
    Brass because it's softer. So the heat, plus whailing on it a bit to help break loose the rust will aid in removing stubborn stuck fasteners without boogering them up beyond recognition. If you give it hell enough it can still deform tho, even with brass, especially if it's allready hot.
  12. MetalMagician
    Good lord this thing is a pain in my arse
  13. commrad
    commrad New Member
    Red Hill, GA
    I think the softer brass doesn't bounce off the bolt like steel does, not buggering it up is just an added benefit.
    and yes they can be a PIA, I just pulled a bike apart and it took 2 days to get the pivot bolt out.
  14. MetalMagician
    alright so today the motor is out and on the table, the frame is in my car so i can fix a crack, and the front axle is, well, junk. i have pictures. they will be put up shortly i promise:smile:
  15. MetalMagician
    Well went to fix my frame to find out there are multiple cracks. It's unsafe so I'm paarting the bike out. Let me know what you need
  16. Metallican525
    Rockville, Maryland
    Well, that's massivly unfortunate, maybe you can score another parts bike/frame in good shape and continue on with your project, with many extra parts too.
  17. McViffer
    McViffer New Member
    Northern California
    Dont give up so easily.
    I have naked frames that need homes. Cheap, and they come with front axles. Shipping from Sacramento. PM me for more info.
  18. MetalMagician
    Well the reason why this is the funk straw is that I have to put a lot of money in it already and when I found out I needed a frame on top of everything else, i considered it just too much money. I found another newer vfr I am going to pursue for less than what I'd have to put into this one. I really do appreciate the offer though
  19. slowbird
    slowbird Member
    Toronto, Ontario.
    shortest rebuild thread in history
