Flapper mod+OEM air filter+snorkel mod,Pair valve unpluged!
Discussion in 'Mechanics Garage' started by sunofwolf, May 28, 2014.
  1. Badbilly
    Probably only as forum members and not in the biblical sense.
    #41
  2. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    Hmm I would think putting a GUN MOUNT in the intake would restrict air flow but what do I know.
    #42
  3. VFR777
    VFR777 New Member
    Kansas
    Ease up on'em big guy he's learning...:soap:
    #43
  4. TNRabbit
    TNRabbit New Member
    Woodford, VA
    FYI: No filter or airflow restriction is going to "lean out" a fuel injected vehicle. They have a Mass Airflow Sensor that adjusts the fuel or incoming air. At worst, intake restriction would limit top end power.
    #44
  5. Carolina06HondaRider
    Carolina06HondaRider New Member
    This^^^^^^^
    #45
  6. kj4eoz
    kj4eoz New Member
    Front Royal , VA
    I know how to put gas in my bike :) lol Thanks mom
    #46
  7. tinkerinWstuff
    The VFR only uses a Manifold Air Pressure sensor. There is no airflow sensor like there is on an automobile. If there were, people wouldn't be able to throw their snorkels in the trash.
    #47
  8. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    For the love of god, someone shoot this thread.
    Now look what you've done, you've sucked me in.
    The pair valve is a pollution device. That is it, it introduces fresh air into the exhaust gases to finish burning excess fuel in the pipes left over after combustion, and they only open on a closed throttle (overrun).
    All that removing them does, is removes the annoying popping noises from exhaust on overrun.
    I've done it on mine because the noise annoyed the crap out of me, & to remove excess junk from top of motor.
    The snorkel and flapper valve are a performance item & has to do with air velocity and pressure to velocity stacks, if you think that millions of dollars of development and multiple engineers got it wrong, then by all means remove them. Disconnecting the flapper will make the bike starve for air at high revs, and removing it will make the bike lose bottom end.
    Air box mods are like people who think that replacing the header pipes with after market ones will improve performance, highly unlikely, it takes a very expensive hand built job to make any improvement.
    Go ride and enjoy the VFR for what it is, a great all rounder with personality.
    I had a mate years ago who would spend all his money on performance upgrades, and would sit there talking for hours explaining how the mods had transformed his bike and why, the bit that never changed was when we left for a ride together, he always arrived at the destination ten minutes after everyone else. And the old bloke with the standard old bike, who had never even adjusted the suspension since he had bought it, was always first.
    #48
  9. Carolina06HondaRider
    That's not entirely true but I get what you mean anyway...
    #49
  10. sunofwolf
    sunofwolf New Member
    WeLL I like to tinker, but none told me what size wrench adj throttle cable by the engine-the cable has some slack. -I lube the cable but that stinky little bolt-nut was so small I didn't have a wrench to fit it.:soap:
    #50
  11. tinkerinWstuff
    I'm confused :confused: what part are you disputing? The image documenting the lack of a mass airflow sensor comes from Honda's official website world.honda.com
    #51
  12. sunofwolf
    the vfr does adj for a after market air filter like the piper cross-how it does this I don't care.:doh::horn::hi2::laugh::kc10:
    #52
  13. sunofwolf
    the vfr does adj for a after market air filter like the piper cross-how it does this I don't care.:doh::horn::hi2::laugh::kc10: The pair valve does actually help in cold starts-so for now its working-best to leave it alone for now-later on I will remove it with block off plates. Still don't know what size the throttle adj screw nut is, maybe 6mm. As usual I answer my own questions.:smiley_simmons::fencing::pisser:
    #53
  14. Badbilly
    Thank goodness someone has the fortitude to set trends around here.
    #54
  15. tinkerinWstuff
    I'll answer anyway; the ECU measures barometric pressure, intake manifold pressure (also called manifold air pressure), all weighed against throttle position to figure airflow and adjust fuel flow.
    #55
  16. sunofwolf
    I all ready knew Honda uses Black Magic and adj for the filter!:boink::lever::spider:
    #56
  17. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Another spider emoticon. But why????
    #57
  18. thegreatnobody
    thegreatnobody New Member
    Little Rock
    Because SoW
    Sent from my fancy telly.
    #58
  19. sunofwolf
    Pilskin doesn't like spiders-but I thought snakes eat tasty spiders.
    #59
  20. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    What I have gathered from reading this thread is to leave the bike alone? I think my model of early 5th gen has a lot less crap on it than later models and vtec bikes have anyway.
    #60
