I have a 1984 VF700F. Just cleaned, rebuilt carbs - have a constant leak on the #3 carburetor intake. New float valve - leaks no matter the float height adjustment. Only leaks when bench tested using the fuel pump; doesn't leak with just gravity. Any thoughts? Thanks
I'd suspect the seat... mine did this 3 times before I just switched all the seats and floats around & it cured itself ..
