FLUSHING FRONT FORKS
Discussion in '1st & 2nd Generation 1983-1989' started by a1gatorz, Sep 5, 2019.
  1. a1gatorz
    a1gatorz New Member
    Petaluma CA
    Hi all , I have a 1987 VFR700F2 . The front fork fluid has not been changed in years . So , my ? is ? What is the best product to flush out the fork tubes after I have removed them . Springs out . I have been told Kerosene , sea foam . My local Honda shop told me to just use some cheap ATF a few times . Then use the proper Wgt . Honda fork fluid .
    Any & all suggestion welcomed !
    THANK YOU !
  2. Boomtank
    Boomtank New Member
    St. Louis, MO
    When I did mine, I flushed them with some ATF then sprayed all parts with some carb cleaner. But I was also painting them as well.
    Sent from my Moto Z (2) using Tapatalk
    Cheap ATF. It's essentially what came in the forks from the factory. (7.5w)
  4. squirrelman
    i used gasoline for its solvent properties to flush out the last of the shiny metallic-looking micro flakes. best to remove forks from bike and drain upside down.
  5. a1gatorz
    a1gatorz New Member
    Petaluma CA
    Thanks guy s. The stuff coming out is beyond bad! I do have the tubes out & upside down .My concern was all the particles I am finding in the old fluid.
  6. squirrelman
    just keep washing it out.
  7. straycat
    Can of Brake Clean, gets them squeaky clean
    Boomtank likes this.
    How many miles on bike?
    You're bushings are very likely toast. Even cleaned out and new fluid, you're fork action is probably going to be poor.
    And flushing forks and adding new oil historically is followed by previously dry oil seals starting to leak as a thank you for your hard work. Seen that MANY times.
