Fork Differences
Discussion in '3rd & 4th Generation 1990-1997' started by Delmumbles, Sep 8, 2015.
  1. RVFR
    LOL Thanks for breaking up my long winded response, whew, when I get typing, like I talk, I've been known not to breath, your version is way easier to read. Yea, bring on your questions.
  2. lynx
    lynx New Member
    SWEDEN
    :smile-new: :smile-new:
    I want to do a full front end upgrade on a VFR750 ( 1994-1997 ) with as little hassle as possible.
    I do not want to use a USD fork.
    I do not want to change the geometry on the bike.
    Which route to go ?
    ...Anyone have a fully functional recipe ?
    ( 1994-1997 ) VFR750
    Fork suspension travel: 140 mm
    Rake: 26.0°
    Trail: 100 mm
  3. Terry Smith
    I did this to my 5th generation VFR:
    Fork lowers and cartridges and caps from VTR1000F
    0.95 kg/mm springs from RaceTech
    Gold Valves for compression and rebound, C32 and RH16 shim stacks
    CBR600F4i calipers and 2003 CBR600RR master cylinder
    Wheel, axle, discs all standard VFR
    Homemade adapter brackets for standard VFR mudguard
    Bars and triples are stock.
    You should be able to do the same with your VFR, but you would need to confirm the axle length and disc spacing. I suspect the 96 probably uses the same spacing as the VTR1000, in which case it should be easy. I also have a VTR1000F if you need any measurements checked.
    VTR caps and dampers enable externally adjustable rebound damping, but are not essential. VTR lowers enable you to use nice 4-piston calipers. The Gold Valves can be used in your stock cartridges, or the VTR cartridges.
