Fork seals and what else?
Discussion in '6th Generation 2002-2013' started by Big_Panda, Mar 4, 2017.
  1. Big_Panda
    Big_Panda New Member
    Simi Valley
    So I noticed my fork seal leaking pretty good today after a ride up and down the 33. I figure If one has to be replaced its worth replacing the other one as well. My questions are:
    How difficult is this process on a 6th gen? I'm fairly mechanically inclined but have limited tools.
    If I am going to replace the fork seals what else is worth doing? What else isn't massively expensive, is in the same area, and would be a good idea to replace while I'm doing fork seals?
    If this is a shop job, about how much am I looking at? I know shops across the US vary but what is a ball park figure I should be looking at? I live in SoCal so I'll add about 15% to out of state figures.
    Thanks for your time and info everybody.
    BP
  2. Terry Smith
    There's about 2 hours work involved, the only thing special needed is a fork seal driver, but I use a 2 foot length of PVC conduit pipe that is just slightly bigger id than the 43mm fork od.
    You may want to replace the upper and lower bushings, these are a wearing item that allows the fork tubes to slide against each other. You may need new copper sealing washers for the bottom of the forks.
    Definitely get a torque wrench.
  3. V4toTour
    V4toTour New Member
    TRY CLEANING IT FIRST. It's amazing how the first reaction is to rip everything apart. Dust and dirt can get in there.
    [video=youtube;nEzjdFQp6IM]https://www.youtube.com/watch?v=nEzjdFQp6IM[/video]
    I recommend this thing: https://www.amazon.com/Risk-Racing-...F8&qid=1488689812&sr=8-1&keywords=seal+doctor
    Incredibly overpriced for a chunk of plastic, but it's alot easier to use on your hands that a thin slip of plastic. You just clip it on the tube and slide it down. It has two different edge profiles, one for the oil seal and one for the dust seal
  4. Big_Panda
    Simi Valley
    i feel like i could make one of those retty easily
  5. duccmann
    Had mine done at wheels in motion when I first purchased my bike. Remember it really wasn't that expensive--- but that was 6 years ago and since replaced again installing Jamie's inserts
    Gods luck B
  6. Lint
    Lint Member
    Simi Valley, Ca.
    Mine never made it past the oil seal. Just got all messed up. It was a waste on my time.
  7. Terry Smith
    Just try a thin feeler gauge; maybe that will be all you need.
