Front Brake Drag
Discussion in '6th Generation 2002-2013' started by Big_Jim59, Jun 25, 2016.
  1. RVFR
    Oh man I feel your pain...almost. When I took the wheels off for powder coating, I looked em over making sure they went back the same way, luckily or smart on Hondas part they put cast arrows on the rim and scribed the disc carriers. I can see this happening, that and yes you now know the shim collars are different left to right SMH crazy huh. Your on track now, you'll be the new go to guy from all the experience you've had.
  2. Allyance
    Allyance Insider
    Brazil
    East Bay, California
    I know the feeling, after rebuilding the front forks on the '83 (second time), while putting the left caliber on, I got the disk between the back of a pad and the caliper, didn't sound very good! Glad you got it sorted out.
  3. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    I have been rather obsessed with this problem. The left side axle shaft didn't fit like the book said, with the scribed line aligned with the fork leg. I knew the disk were not offset and I knew that my spacers were on the right sides and last night, just as I was going to sleep I thought "I'll bet the offset is in the wheel itself. It has to be." I got out in the shop before 7:00 this morning to test my theory and it was right.
  4. GigemVFR
    GigemVFR New Member
    TEXAS
    I agree with Long, the best thing is to just walk away for a while/day and come back to it later. If you don't you either get so frustrated you wind screwing something else up and making the situation worse or you just keep going round in circles and accomplish nothing except ruining your day. Once you are relaxed and have a clear head, the solution usually presents itself fairly easily.
    Glad you got it solved. So what's next?
  5. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    It's like the old saying, "the first step in getting out of a hole is to stop digging." I have new pads on order (It needed them) and so I will wait on that shipment. I have a pretty full week with work and all. I may find time to get the tire swapped round and reballanced. I will get it back on the road eventually.
  6. Diving Pete
    Well done Jim,
    Solved.
    Don't worry about what was, or worry about second guessing yourself, move onto fix the next problem..
  7. Gator
    Gator Member
    Here is thanks from some future guy that you saved a bunch of frustration.
  8. NormK
    NormK New Member
    Don't beat yourself up too much Jim, the only person who doesn't make a mistake is the person who doesn't do anything
  9. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    Yep, I feel better. It could have been worse. I could have bent my new (used) disks!
  10. GigemVFR
    GigemVFR New Member
    TEXAS
    So what's the update on this Big Jim and how are things coming? Did the smoke issue resolve itself? Have you got everything back on track where you can ride and enjoy it?
  11. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    It is better. I have been tinkering with it. The shop I work at did the electrical recall but broke my fairing where I plastic welded it. I had to fix that again. I am still not happy with the fairing. It think it was tweaked in the wreck that is pretty obvious for some fairing rash. I have been finding and replacing stripped out and broken well nuts but I think I have them all. I have a gap at the bottom of the fairing, in the front, of about 1/4" that drives me nuts. The fairing seems to fit fine except for the gap. (I know I am being picky)
    The front wheel still feels a bit snug but that could be for the new pads dragging.
    Also, I found a length of what looks like 3/8" gas like running from under the tank back to the rear of the tail, under the seat. It is not connected to anything. It's just sitting in there and terminates around the top of the rear cylinder cover.
    Weird.
  12. Terry Smith
    Would that be an extension to the tank breather line? Mine terminates at an elbow joint around the rear cam cover. IIRC the original extension had been burning itself against the rear headers so I threw it away.
  13. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    The line looks old and doesn't look like an OEM part. Given that the bike is bone stock I can't see any reason for it being there.
    I got the fairing back on. I took my time and checked alignment. I bent tabs and chased all the threads with tap and die. It has a better alignment now and the gap in the front is less noticeable.
