Front brake reservoir level check
Discussion in '7th Generation 2010-Present' started by rules, Jun 23, 2024.
  1. rules
    rules New Member
    South Africa
    Hi All
    I just want to double check, in which position should the VFR be when checking the brake fluid level? Side stand, main stand, bars facing forward?
    Actually have a copy of the workshop manual but it does not say in there either.
    Thanks,
    R
  2. bmart
    bmart Member
    Charlotte, NC
    If it is like all other bikes I've owned, the top of the reservoir should be level. That will allow you to add to the top mark and still fit the compressed bladder and lid without spilling. But if it is low...look at your pads. They generally wear near 1:1 rate. And if you fill it with old pads, when you put new pads in, you'll need to remove most of the fluid.
    Totaled TL likes this.
  3. rules
    rules New Member
    South Africa
    Yeah that would make sense, then on side stand and bars all the way to the left would be level. I did have a look and the pads are fairly low, back and front, so probably a good idea to do those sometime soon, and then monitor the fluid level.
  4. BMWguy22
    BMWguy22 New Member
    Let me know how this goes for you.
    I'd like to change the fluid in my system but don't want to risk dumping brake fluid all over the paint/handlebars.
    I recently installed a center stand which raises the rear end, so maybe that might be the best bet.
  5. Totaled TL
    Totaled TL New Member
    Louisville, KY
    Put some rags on your tank, bars, around the resv., etc. Anywhere brake fluid could spill. You'll thank yourself should you spill some.
    BMWguy22 likes this.
    I COVER my bike in old blankets/towels anytime a res cap comes off for any reason. Doesn't matter how outlandish something may seem, when brake fluid is involved, it will find a way to fucking happen. HATE BRAKE FLUID!
    BMWguy22, mello dude and bmart like this.
  7. mello dude
    Romania
    Fucking agree on that!! :Rolleyes:
  8. BMWguy22
    BMWguy22 New Member
    fuckin' eh!
    :facts:
    mello dude likes this.
