front end problems
Discussion in 'Mechanics Garage' started by Chris71Mach1, Mar 30, 2010.
  1. supertex
    supertex New Member
    Just moved them from 1 bike to another and it was pretty simply done. After I got the damn top triple off that is.
  2. tinkerinWstuff
    seriously, the problem with ball bearings is the minimal amount of contact surface. The ball is hardened and so is the race so think about how much surface against surface area there is. The ball bearing is essentially a dull nail pushing against the race. Ball bearings and their races are typically lesser expensive (irregardless of what Honda charges for them).
    Take the higher end machining centers for example. The lighter faster machines went to bearing trucks that used balls, some time in the '80s I think. This gave fast nimble movements over box ways but they sacrificed rigidity because of the lack of contact surface. In recent years, these same higher end machines have started using linear roller bearings which exponentially increased the contact area and rigidity (over balls) while maintaining the speed and accuracy of a ball bearing. Because of this increased surface area, I would put a "lesser" quality roller bearing against a ball bearing any day.
  3. squirrelman
    Increased contact area increases friction, reducing to a degree the rider's feel for wheel traction at the contact point with the tarmac.
  4. betarace
    betarace New Member
    Middleburg, VA
    nope, but thanks for playing
  5. tinkerinWstuff
    may be a fair assumption but I'd disagree. Looking for proof... Essentially the difference is; while yes, you do have more surface, the surface is ROLLING. And since you have more ROLLING surface with the weight better distributed along that surface than on a ball bearing, you could theorize that there is LESS friction.
    This doesn't directly address your point but interesting all the same. From: HowStuffWorks "How Bearings Work"
  6. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    This is a great thread and I just can't resist because I get to use the word BALLS!
    I ended up with a set of All Balls tapered roller bearings one day purely by accident so I stuffed them in my fifth gen even though there was no perceptible play in the stockers which had a total of 7k on them. I was really shocked to feel the difference in the level of feedback I got from the front end with the tapered rollers. They must improve feel due to the increased contact area. I don't know why but it was the best bang for the buck I have ever had in terms of modifications!
    Just my 2 loonies worth.
