Front end swapped, delinked, desmogged....now I'm getting somewhere
Discussion in '5th Generation 1998-2001' started by cbrcrx, Oct 14, 2010.
  1. NorcalBoy
    Gold Valves with the High Frequency Race Rebound valves and springs will fix the stock forks. Swapping tubes to delink the brakes seems odd to me.....the linked brakes are better than what most folks let on about. If the argument is trail braking, the linked brakes are capable of that.
  2. Mark 024
    Mark 024 New Member
    Sydney, Aust
    Great lookin bike man.
  3. cbrcrx
    cbrcrx New Member
    Not getting back into the linked brakes arguement. It's been covered enough. To each his own.
  4. pap11y
    pap11y New Member
    Sydney
    Can you do the VTR replacement without loosing linked brakes?
  5. ridervfr
    Lame Brain = Linked Brakes, car think for bikes :sad: wont even get into the :bullshit: argument about ABS. Cheers
  6. cbrcrx
    cbrcrx New Member
    No. If you just want to add rebound adjustment, I think you can swap out the internals with the CBR600F3 and maybe the Superhawk. I've never tried. My main goal is always to ditch the linked brakes. My last 5th gen I swapped the whole front with an F3. This one I just did the forks.
  7. 02 VFR Rider
    02 VFR Rider New Member
    so you can swap out the stock internals of the forks from a CBR??? and still use the VFR tubes???
    will this work on a 6th gen as well???
    I just want more adjustment, I will do the springs and valves, but would like to have comp and rebound adjustment.
  8. cbrcrx
    cbrcrx New Member
    6th gens are 43mm. I don't do the VTECs, so I don't know. No offense. You might try F4i forks?
  9. nobby
    nobby New Member
    spain
    Just 1 question re the above: is that a vfr front fender you are using? how did you match it to the vtr forks??
    great job so far sir!! inspirational stuff, im collecting the parts at the mo to do the same..
  10. cbrcrx
    cbrcrx New Member
    That is the stock fender. I just bought strips of aluminum form Home Depot and shaped them for brackets. Easy, cheap and light weight.
  11. nobby
    nobby New Member
    spain
    Just what i wanted to hear! im sure i saw on here somewhere someone paying$$$$ for cnced adaptor plates....
    sorry, just 2 more questions, your vtr forks run standard springs?(i d heard vtr forks are way soft?) and are your brakes biting vfr discs or vtr discs??
    cheers!!
  12. cbrcrx
    cbrcrx New Member
    I saw that thread where the guy paid hundreds for brackets, but what's the point? Anyway, I ran the VFR springs and heavier fork oil. It handled great for me, but everybody is different. At worst you have to get the revalve kit. It is the stock front wheel and rotors. You only have to put one washer between the calipers and the forks to space it properly. Everybody thinks this is way more complicated than it really is. Just do it.
