Front end wobble or shimmy.
Discussion in 'Mechanics Garage' started by bentleyss, Jul 13, 2011.
  1. bentleyss
    bentleyss New Member
    Englewood, Florida
    I have a 1998 VFR800. I had a vibration in the front end at cruising speed. I was due for tires, so I changed out both tires. I checked the rotors and the L one was slighty warped so I got a new ones. As long as I had the wheel off, I replaced the bearings, re-did the front shocks and put in a new tapered bearing set from All Balls. Now when I'm slowing down to below 20mph. I get a front wobble. What am I missing here. I've read the other posts and I think I covered everything. Any help appreciated.
  2. camo
    camo New Member
    The Heartland
    Wheels balanced? Tire pressure?
    Consider that you could have something loose or out of round in the back. Swing arm pivot rear, wheel bearings. How is your chain tension?
  3. FoothillRyder
    FoothillRyder New Member
    Sierra Foothills
    Is this a 'hands off' wobble? In other words, if you keep your hands on the grips can you even feel it?
    I second the question about tire pressures; but I doubt an out of balance tire would cause anything at 20mph.
  4. fastrax203
    fastrax203 New Member
    Chesapeake, VA
    This is similar to my situation.
  5. bentleyss
    Englewood, Florida
    This is a hands on wobble. I'll check tire pressure in AM. but I think it's OK. But I'll double check it.
  6. Badbilly
    First place to look IMO is for a sloppy steering head bearing. You could try tourqueing it to spec but replacement is better especially if yours is a ball bearing type. Lots of stuff on this here from the better mechanics.
  7. squirrelman
    It's harder to adjust and set tapered bearings than OEM balls, so check there, as mentioned.
    Could also be loose front or rear axle nut or pinch bolts.
    Is your bike wandering about in an S-shaped curve left and right ??
  8. tinkerinWstuff
    don't discount geometry as a cause. Not using OEM tires sizes, incorrect preload on front and/or rear for your weight. Adjusted front fork height, etc...
  9. bentleyss
    Englewood, Florida
    Thanks for all the information. I've got tomorrow off so it will be wrench time and double checking everything. I think I'll start with the steering stem bearing adjustment and work from there. Thanks again.
  10. bentleyss
    Englewood, Florida
    This is an update on my front end wobble. It's been a little while. OK I changed out rotor as one was warped. I balanced the tires and re-adjusted the new needle bearings. Tire pressure is good. Brake pads are good. Chain tension is correct and it's lubed well. Sprockets are good. I still get a wobble at low speed (less than 25) with hands on the bars. I'm going to remove the tire and re-balance the front wheel, but I don't think that is the cause. Any other ideas on this. The bike is a 98 VFR with 75000 miles on it. I ride it to work daily. RT of 108 miles.
  11. slowbird
    slowbird Member
    Toronto, Ontario.
    How old are the tires? Any unusual wear? Cupping?
  12. bentleyss
    Englewood, Florida
    Sorry, forgot to mention that both tires are brand new. No unusual wear at present.
  13. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    I have a similar issue. replaced the head bearings last year and this feels like the symptoms of worn head bearings, must be wheel bearings or swingarm bearings gone, or maybe the head bearings need checking.
