front rotors mounted backwards
Discussion in 'Mechanics Garage' started by jesusbuiltmyvfr, Mar 17, 2011.
  1. jesusbuiltmyvfr
    jesusbuiltmyvfr New Member
    cheeseheadlandman
    Got my wheels back from paint, and when I installed the front I notice the rotors were mounted on the wrong side. The rim and tire are mounted correct. But the arrow on the rotors are facing backward. Will this be a problem?
  2. JTC
    JTC New Member
    Watts, CA
    Definitely flip them around to the correct position.:crazy:
  3. 02 VFR Rider
    02 VFR Rider New Member
    agreed, flip them
  4. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    +3, they're directional for a reason, they will bite the pads differently and not stop as well.
  5. crustyrider
    crustyrider New Member
    North Country, New York
    or you could ride it backwards all the time
  6. Metallican525
    Rockville, Maryland
    Hell yes, but pics and video or it didn't happen :worthless:
  7. iyad202
    iyad202 New Member
    I know this is an old threax but I had a similar case. I ordered the wrong side rotor and it is costy and a lot of hassle to get another one, I installed the left rotor part on the right side of the wheel and it works perfectly (the other side is correct by the way). It doesn't look like there is much difference in the holes and it is really hard to see a directional pattern unless you compare and look at the arrow. What would happen if i keep them the way they are?
    By the way my bike is not an abs model, vfr800 6th gen 2008
  8. Terry Smith
    My opinion (and it is just that) is that just the drilling pattern is different, and the only reason for the difference is fashion. I can't think of a reason why this would have any affect on braking performance, safety etc. If it feels normal (and I'm guessing you had a buckled disc before so it will feel wonderful) just ride the thing.
  9. RVFR
    To funny, I almost did this very thing, but spotted the arrows. Then also thought whats the diff? hmm a closer look shows nothing, but since I'm not using new pads, figure I best put he same disc with the same pads
