Front sprocket: solid steel or rubber damped?
Discussion in 'Mechanics Garage' started by Camp, May 11, 2020.
  1. Camp
    Camp New Member
    Easton, PA
    Personally, I noticed a negative difference in harshness on my 08 going to a solid sprocket when i installed a chain kit. Now that I have a FactoryPro star kit and a 5th gen Oberon slave ready to go in I've ordered a JT rubber damped sprocket as well. Hopefully all goes. Smoooth! Running 16t/45t btw. Will advise.
    The front sprockets aren't actually "damped" like a rear hub. It just has rubber vulcanized to it to reduce noise transmitting from the counter shaft.
  3. Camp
    Camp New Member
    Easton, PA
    I stand corrected in my understanding then, thank you. I was under the impression that it was an inner and outer 2 piece with rubber in between.
    Still all gain no loss replacing it tho. Quiet drivetrain is good as far as I'm concerned.
    Captain 80s likes this.
  4. ridervfr
    Belgium
    usually after market counter sprockets are just steel sans any kind of rubber attached - (least to my memory.) :wheelie:
  5. squirrelman
    imo, the rubber does reduce noise and vibration.
  6. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I've not noticed any difference between rubber and no-rubber.
