Front tire removal and mounting/balancing
Discussion in 'Mechanics Garage' started by reg71, Aug 7, 2006.
  1. DaViffer
    DaViffer New Member
    Erie/Pittsburgh
    I just mounted two new pilot road 2s, and now I'm having issues getting the front wheel back on. Service manual said to torque the axle bolt and right pinch bolts, bounce the front end a few times, then torque the left side. Still can't manage to get the proper clearance with the calipers. Sound like a problem with the calipers/pads?
  2. Joey_Dude
    Joey_Dude Member
    North Georgia
    Sometimes I have troubles putting the wheel back on and what works for me is to just pull the brake pads out of the left caliper. I know it's not ideal but when it's 10 pm and you gotta go to work next morning you get pressed to solutions. Then I'm able to put the wheel back on and I re-insert the brake pads on the left caliper and I'm ready to rock 'n roll!
  3. 02 VFR Rider
    02 VFR Rider New Member
    Great thread Reg :thumbsup:
    :cheersaf::cheer2::whoo::vtr2:
  4. VifferDude
    VifferDude New Member
    Sydney Australia
    Reg,...It's better to 'Look' the fool, then 'Be' the fool
  5. reg71
    Sikeston, MO
    wow, you resurrected one of my old ones... this was not too long after I joined vfrworld. I still remember changing tires by hand. UGH...
  6. Slothrop
    Slothrop New Member
    northern lower Michigan
    you use your feet now?
  7. bitterpil
    bitterpil New Member
    Northern Virginia
    Reg's post helped inspire me to do my own tires. It took a bit on the first try but I think it was worth learning.
  8. bitterpil
    Northern Virginia
    JD .. Had the same but I just spread the brake pads with my thumb and that got them far enough apart to slide over the disk. .. I see that popping them out however could be quick. I was glad to change my tires because When I pulled the caliper free and the brake pads fell out... (not supposed to do that). I had recently had my dealer to the brake job but now I think I will be doing brakes as well as tires in the future.
  9. DaViffer
    DaViffer New Member
    Erie/Pittsburgh
    Well I figured out why dumba$$ here (that'd be me) was having trouble with the front wheel. The pilot road 2s that I got have opposite facing grooves when comparing the front tire to the rear. I tried to mount the front the way it "looked" like it was supposed to go, and couldn't get the necessary clearance for the wheel to spin once mounted. FINALLY took a closer look at the tire after noticing the wheel itself was backwards, and all I had to do was flip it around. Slipped right on. Kinda weird to look at, though, since the tread is backwards to any other tire I've ridden on before.
  10. rufussrgnt
    rufussrgnt New Member
    Lewisburg, TN
    I'm not trying to be a smartass here, but the word "front" on a tire has nothing to do with the direction of rotation. It simply means that the tire goes on the front of the motorcycle. You'll probably find that the rear tire says "rear" on it.
    I've never mounted a tire that didn't have a rotational arrow on it.
  11. reg71
    Sikeston, MO
    yeah, it was quite the ordeal. as you can see from reading the full thread, I left up my mistakes in their entirety. I do this so that others can learn from my mistakes and not have to go through as much as I did.
  12. supernatural5
    supernatural5 New Member
    Martinsville, IN
    Now that it cost $48 to mount and balance, I've been doing my own. However, I am unable to do the rear. In the pic above you are using the tapered spools on the rear. Please explain how this is possible, or what I missed.
  13. supernatural5
    Martinsville, IN
    Never mind, Ic.
