Fuel cap replacement
Discussion in '1st & 2nd Generation 1983-1989' started by Sells, Jun 15, 2020.
  1. Sells
    Sells New Member
    Karratha, Western Australia
    Hi guys,
    My rescued '89 VFR 750 FK had a wrecked lock in the fuel cap. I bought a replacement, but the cap surround has larger bolts and a slightly larger circumference to the holes. The new cap is the same as a number of models. I suspect the tank might not be off this model, but am unable to find a match to the original on the bike. Modifying the new cap, I could punch the roll pin and put the new centre in the old surround, but am hoping there is a new one available somewhere.
    Cheers :) 20200504_135411_1024x768.jpg
  2. Paul Myers
    Paul Myers New Member
    Kingston, Ontario
    Is the center cap the same size.
    there should be two small phillips head machine screws that hold the actual cap to the hinge.
    Can you just unscrew those and move it to the original mounting ring and hinge?
    Sells likes this.
  3. Sells
    Sells New Member
    Haven't seen the phillips head screws, but I could change it if I knocked out the roll pin hinge as they look the same.
  4. squirrelman
    fake cap
    Sells likes this.
