Fuel pump absolutely necessary on a 1985 VF700?
Discussion in '1st & 2nd Generation 1983-1989' started by FasYankee, Mar 17, 2014.
  1. tinkerinWstuff
    Like I said; explain how a company with a team of highly paid engineers, that wants to sell performance products to broke eighteen year olds is going to put an unnecessary component on it making the product cost more or cut into their profits?
  2. tinkerinWstuff
    Oh, and you should have rode over Vail Pass with Reggie and I last fall and see just how much pressure buildup WASN'T happening in the tank at 30degrees and snowing. Had a bike broke down then I think Reg would have thrown me off a cliff.
  3. Jeff_n_Franklin_Tn
    Jeff_n_Franklin_Tn New Member
    Franklin, TN (Nashville)
    Just read a post from friend in Holland (Holland is below sea level) Who has rebuilt many VF750F's from the ground up. A mechanic on a racing team for these bikes. He knows his stuff.
    He replied that he has problems with fuel starvation with the tank fed directly to the carbs. So this disproves the "elevation, atmospheric pressure theory". If Jamie Daugherty can make this work. I don't see why anyone else can't make it work either.
    I'm tellin ya there has to be a solution and a simple one. :smile-new: Having to stop for fuel every 60 to 90 mins would just suck.
  4. TOE CUTTER
    There is a law of physics involved in that but it is not gravity.
  5. tinkerinWstuff
    You seem to be avoiding this question and grabbing only at the answers you WANT to hear:
    You can get a generic 12v 3-5psi pump for like $30 bucks. I had a thread on it somewhere and others have done the same thing. Not sure if I still have pictures....
  6. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Yea what's the big deal?? Put a pump on it. Well worth the money compared to the hassle. "Having to stop for fuel every 60 to 90 mins would just suck."
  7. tinkerinWstuff
  8. Jeff_n_Franklin_Tn
    What "I WANT to hear"? I have heard only one answer to get around the problem and that's buy a pump. I have no argument about that. The old Honda accord pumps I believe it is. The point of this thread is that it does work without issues for others without a pump. You seem to have just thrown in the towel and given up.
    Pull the petcock off the tank and tell us how much fuel comes out of it. You'll get all of it out but a cup or so.
  9. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    Yes, this topic has been hotly debated, however much of it is opinion and suspicion. I will tell you that all of my first generation VF's run gravity feed and they run perfect and will use all of the fuel from the tank.
    If you have the tank off the bike and on the bench - then open the petcock - won't all of the fuel drain out? Sure it will. That's exactly what happens when it is on the bike too. I'm not sure where the 1/3 tank thing ever started but it simply isn't supported by fact.
  10. tinkerinWstuff
    And still, no one can offer any guesses to my answer my question
    I'm not calling Jamie a lier. But because it works ok for one person on warm track days doesn't mean it will work for you.
  11. 34468 Randy
    My ears are ringing after that one.
  12. JamieDaugherty
    Fort Wayne, IN
    Not sure what question you are referring to.
    My bikes are not track bikes. They are street bikes ridden in 40-90 degree temps, city and rural conditions, etc. Gravity feed has been done many times to first gen VF's. Only a few people have not been able to make it work - and my conclusion was something else was wrong in the system in those cases.
  13. V4toTour
    V4toTour New Member
    +1 on the 42s
    I've got one squeezed in one of my CB-1's. Had to shave the mounting tabs off to get it to fit, but 40 bucks available everywhere. Hard to beat for that price.
  14. tinkerinWstuff
    Sorry, I assumed you read the thread. I mostly started with statements but it became a very specific question later on the page:
  15. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    I gotta side with tinker on this one. Honda engineers are not known to stuff useless doodads in there for no reason.
    Could you do it? Sure, but it probably won't run as well as if you had a pump on there.
  16. tinkerinWstuff
    And don't get me wrong, I certainly don't mean that Honda and their engineers can do no wrong. But when the organization does f' up, it's usually because they were being cheap (I.e electrical connectors, RR, line boring & metallurgy).
  17. squirrelman
    Pump HAS to be there for a good reason.
    But i've always carried a short length of fuel line under the seat to connect tank to carbs if the pump quits and gravity will get me home.
  18. TOE CUTTER
    If you can ride my bike off on a gallon of fuel, gravity fed, I will stick the title in your pocket as you ride off and please do not look back. If you need my help to push the bike back.........your mom or sister better have some mad skill's orally. Bike,gas, and title are here for the taking.
  19. TOE CUTTER
    Just say'n
  20. Markvfr800
    Markvfr800 New Member
    thats like ovekill to a simple obviuouness, but icommend the effort and the science knowledge.
