Fuel Pump Assemblies, 5th & 6th Gen, Same?
Discussion in 'Mechanics Garage' started by ridnout, Sep 12, 2016.
  1. ridnout
    ridnout New Member
    As the title suggests, are the 5th and 6th generation fuel pump assemblies the same, interchangeable?
    On a side note, on my 5th Genner, I've installed the newer styled fuel filter, as the original unit's flow was obviously degraded.
    I've sourced and purchased and received a 5TH Gen tank, but of what I can find, is that there maybe a 6th Gen one available cheaper than a sixth; go figure. A second set of clothes is slowly becoming a reality with the 5th.
    Thanks group.
    Chad H likes this.
  2. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    Fifth gen year 2001 fuel pump assmbly. 16700-MBG-30 price-$309.48
    Sixth gen year 2005 fuel pump assembly 16700-MCW-D02 price $337.30
    So, doesn't look like they are the same.
  3. ridnout
    ridnout New Member
    I have not removed the 6th gens tank or pump assembly. Are they interchangeable? Has anyone done this?
    I do know that the original pump assembly has a fuel filter that is straight, no bends; however, the filter model has been changed to a model which has a bend and eliminates the bend found between the pump and filter.
    Would the model numbers be different because of this change to the filter?
    At the end of the day, are the parts interchangeable? Has anyone done this?
    Thanks.
    Later on, I may remove the tank...to compare. That is a lot of work.
    Thanks again group.
  4. tinkerinWstuff
    Pretty sure I used the 5th gen pump in my 6gen tank
    Pump from this smashed tank
    Into this 6gen tank
    Haven't had any issues
  5. ridnout
    ridnout New Member
    Thanks. Since obtaining an extra 5th Gen tank, I'd like to go ahead and outfit it. Believe I can grab relatively cheaply a 6th assembly.
    Chad H likes this.
  6. Chad H
    Chad H New Member
    Friday
    Hello Ridnout! I have no idea if youll ever see this, but im trying to figure out the exact same thing, lol. Did you ever find out if the 5th Gen and 6th Gen Fuel Pump Assemblys were interchangeable?
