Funny little sound when throttle is opened
Discussion in 'Mechanics Garage' started by Underoath87, Sep 23, 2015.
  1. M_Gunnar
    M_Gunnar New Member
    Norway
    I have the same problem, is the sound on your bike. See my video
  2. Gino
    Gino New Member
    Yep, that's the same sound.
  3. M_Gunnar
    M_Gunnar New Member
    Norway
    Did you find out what it was ??? The try to unplugg the hose intop of airfilter, but the sound was Still there
  4. Gino
    Gino New Member
    The sound is still there and I give up trying to find out what it is. It doesn't effect the Bikes performance and hasn't gotten any worse.
  5. M_Gunnar
    M_Gunnar New Member
    Norway
    ok, but very annoyin... I will write if I find out :)
  6. 34468 Randy
    Mine does that too. Hs for years and tens of thousands of miles. I think it may just be the flapper on the air intake opening and closing but not 100% on that.
  7. Terry Smith
    The flapper is vacuum activated, but the vacuum is turned on/off by an electrical solenoid. I suspect it is the solenoid that you are hearing, certainly on my 5G in gear with the clutch in at lights I occasionally hear the solenoid activating if the clutch switch is a little dirty. To test if it is the solenoid, you could unplug the clutch switch (don't worry, it won't make the bike explode, you just won't be able to activate the starter when in gear) and see if the noise stops.
  8. M_Gunnar
    M_Gunnar New Member
    Norway
    I have replaced this switch and the sound is still there....So then it means that it's not a solenoid i will think. Was at the mc workshop and replace this one today, but thanks for the tip
