FYI ... if you need your cams re-ground...
Discussion in '1st & 2nd Generation 1983-1989' started by jack737, Dec 18, 2014.
  1. jack737
    jack737 New Member
    Vancouver BC Canada
    Just got my vf1000F cams back from Colt Cams, he did a nice job on them. This place is a good alternative to MegaCycle, only $368 Canadian for the regrind and Parkerzing. Should be good for another 50,000km. Now I just need to find one more decent rocker so I can put it back together.
  2. Lobotomy
    Lobotomy New Member
    Toronto Ontario
    Thanks for the Info
  3. 34468 Randy
    Why did you need regrinding of your cams?
  4. tinkerinWstuff
    Awesome to see. Seems pretty reasonable pricing.
  5. jack737
    jack737 New Member
    Vancouver BC Canada
    Why did my cams need grinding, look at the middle picture, that was before,
  6. midias
    midias New Member
    Rochester NY
    I have no motorcycle experience with them but they ground my accord cam and were great to deal with and wonderful about answering my questions.
  7. jack737
    jack737 New Member
    Vancouver BC Canada
    Yes, he seems like a good guy to deal with... and the Canadian dollar keeps dropping so his rates keep getting cheaper !!
  8. HOGUE5150
    HOGUE5150 New Member
    WESTERN SOUTH DAKOTA
    This may be a silly question for some...can you get performance cams for a bike like you would for a car?
  9. Badbilly
    Yes, unless the bike is a two stroke or one of those bikes that plug into the wall. Hot cams are even out there for Harleys. Some can increase the horsepower to as much as 50. Here's one source:
    http://www.webcamshafts.com/
  10. squirrelman
    If you think your VF needs hot cams, you need a different bike. The bike's plenty fast as it is, and cam mods almost always sacrifice power at one rpm to boost another, mid or top. Extra lift is always good, within calculated limits, but doncha think Honda
    knew what was best ?? Hot cams often require different valve springs and impose greater loads on components.
  11. tinkerinWstuff
    For many years, the VFR had detuned cams in the California motors. I wouldn't go out of my way to throw money after cams if mine were working fine. But if I NEEDED new cams then I would absolutely consider a different configuration. That's just me.
  12. squirrelman
    ^^^ Yeah, tink, i understand that, and you did a great job chaging yours out, worth the effort and cost.
  13. gxrjocati
    gxrjocati New Member
    sunny surrey,bc
    what about shadbolt in vancouver for regrinding
  14. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Holy shit if I could get 4 cams reground to performance specs for $297 US I am in!
    And being that this is a vtec engine, I could have the heads ported/polished (to flow enough to match the top end requirements of the bigger cams) and milled (for more compression to bring the bottom end torque back up) and do the primary lobes on standard rc45 specs and the VTEC lobes a little hotter. That would result in no low end loss, more mid range and a lot more top end! :eek:nthego:
  15. tinkerinWstuff
    Wow, creative idea!
  16. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
  17. Drlee
    Drlee New Member
    BC Canada
    So this is a older post im interested in how the bike performed after. Im going to give colt cams a call thanks, i need mine reground in my 1984 vf750, the other question i have is and i havent seen this...on the site or other sites ...is the magna cams the same i know different part#s but some people ive talk to say they are but im not about to do that unless im sure because there are a lot of good magna cams out there for cheep...
  18. jack737
    jack737 New Member
    Vancouver BC Canada
    Hi, yes the cams worked great. The profile is the same as stock and the guy from Colt says it was the best profile of all the early v4's. Not sure about using the magna cams on your engine. I'm sure they would fit but I imagine the profile would be ground for a different powerband. Don't have my Interceptor any more, moved on to a new project. I'd recommend Colt Cams, they do nice work. But of course it's hard laying out a lot of dough on something that isn't worth a whole lot. Good luck.
  19. Drlee
    Drlee New Member
    BC Canada
    Hey thanks so I did some research I picked up a magna manual and a interceptor manual and I found the cams have the same specs very interesting
  20. Drlee
    Drlee New Member
    BC Canada
    Well it didn't seem like that much money i'll phone them tomorrow and see what they have to say
