Gas smell when fuel is low.
Discussion in 'Mechanics Garage' started by Brandonb1207, Sep 29, 2014.
  1. Brandonb1207
    Brandonb1207 New Member
    Having a problem with my 2003 vfr non abs.
    After the fuel gets below a quarter tank, and the bike gets hot enough to kick the fan on it emits gas fumes. I've replaced the intercooler pressure cap to help with over heating issues recently, but it still makes the smell if it gets hot enough.
  2. rjgti
    rjgti New Member
    regina sk
    mabe fuel expansion forcing air out the tank overflow line, just a guess
  3. nookiaz
    nookiaz New Member
    Montreal
    Yeah I have that smell too, but not sure when fuel is low, but for sure when engine is hot. The mech guy says it's the heated air that bring upwards the gas smell from the vent hose. Don't know if that's true but no issue with bike operation.
  4. Mark919
    Mark919 New Member
    Detroit Suburbs
    I'd be concerned if the fan kicking on causes you to smell raw gas.
    I'd suggest propping up the tank and taking off the air box while the engine is hot and searching for a fuel leak. I'd be surprised if gas is dripping from the vent line onto the ground but that's an easy first check. When the tank is not full it's hard to imagine fuel coming out of the vent line but maybe the gas cap is goofed up and it's pushing gas into the vent all the time.
  5. Allyance
    Allyance Insider
    East Bay, California
    Since the stock fan blades draw air in from left side and pressurize cavity in front of engine, what I think you are smelling are fumes from vent coming up between tank and dash. If you smelled it all the time, then I think you would have a leak.
  6. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    Did you (or someone else) remove your carbon canister?
