Gawd awful noise
Discussion in 'Mechanics Garage' started by 34468 Randy, Mar 20, 2011.
  1. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    I'm glad it worked out OK, Randy. I couldn't download the video at the job I just finished (corporate blocking), and my dial-up connection at home just takes wayyyy too long. Besides, everybody else said pretty much the same sort of things I would of had to offer. Cheers!
    #41
  2. crewwolfy
    crewwolfy New Member
    Chicago, IL
    I did notice you were rolling the wheel backward; could that have anything to do with it? Or did you check in the same manner when you returned from the trip? Or was it doing this in both directions?
    #42
  3. a90s2cs
    a90s2cs New Member
    Charlotte, NC
    When you shift gears without the motor running sometimes the gears don't engage like they should. I wasn't thinking it was a "false neutral, just a weird neutral, happens to my 450ex all the time... I put it gear when I park it and when I roll it backwards out of the garage it will make that sound until it click into first then back into neutral. I really don't think its anything to worry about.
    #43
  4. 34468 Randy
    Wolfy,
    Yes I did roll it both ways when I took it out the other day and the noise was gone.
    Personally I think it was the chain being too tight and it was placing undue tension on the gears inside. Only the slight chance it may have been a false neatral. But it really did sound like two gears knocking against each other. Like I had mentioned, the rate of the knock was directly proportional to the RPMs that I spun the wheel.
    #44
