General question about used units
Discussion in '5th Generation 1998-2001' started by Andre Yee, Jul 7, 2017.
  1. Andre Yee
    Andre Yee New Member
    Malaysia
    Hi! I found a used police unit in one of my local listings and had a look at it.
    The bike would definitely need some work, I was just wondering how much of a headache it would be to fix
    For starters, the bike is a police model, initially it had broken fairings, so the current owner has replaced that with the civilian spec fairings which unfortunately could not fit the instrument cluster (as seen in the image)
    If I were to purchase the bike he has recommended that I put in the civilian spec instrument cluster in, but I was just wondering if it would be incompatible with this bike as it is the police version
    Besides that the bike has other minor problems like a leaking left radiator and flat battery. Would there be any other thing I should look for or think about as well before I decide to buy this off of him?
    Thank you everyone!
  2. vegaquark
    vegaquark New Member
    Spain
    Spain
    Woha! I felt on a similar one... Broken fairings, little bit bent fork, electrical problems... Did not worth it, but i've learnt a lot on the process... First thing learnt is not to underestimate jobs to be done.
    If i were you i would go for a better unit.
  3. Samuel
    Samuel Member
    Los Angeles County
    If you're not confident making your own assessment, I would recommend that you have someone qualified (e.g. a Honda mechanic or independent mechanic/shop having legitimate knowledge/experience with that model motorcycle) do a pre-purchase inspection for you...
  4. Deadsmiley
    Deadsmiley Member
    Bowling Green, KY
    I vote with vegaquark and would pass on that one.
  5. TOE CUTTER
    Unless you unable to fight off the urge, pass on it.
  6. squirrelman
    not if it still has lights and siren ! :Cheer2: :Cool: :Brick:
  7. duccmann
    Run Forest run
  8. Andre Yee
    Malaysia
    Hahhaha
    Well yeah I like that logic
    I almost wet myself when I turned the key and revved her up... The sound of those gear driven cams were just too good
    Unfortunately in my country this model of VFR are hard to come by so I don't really have much choice if I want one of these
    Just wanted to know mostly about the compatibility of the police model with the normal spec instrument cluster, if there are too many electrical gremlins to sort out
    Anyone have any idea?
