Gipro gear indicator
Discussion in '6th Generation 2002-2013' started by speedpoker, Jun 6, 2009.
  1. speedpoker
    speedpoker New Member
    I just got this setup. Seems to work as described. That is one thing I missed with passing on the CB700SC is the gear indicator.
  2. jay956
    jay956 New Member
    Richmond, Virginia, United States
    can you explain to me why you wanted it? i dont understand them
  3. speedpoker
    Besides just being extremely attracted to red lights it tells me what gear I am in with a simple glance. Sometimes I ride with earplugs because my helmet is a flipup one and pretty noisy and sometimes I ride without earplugs. Determining gear by engine noise can be tough. If smart I could probably calculate by engine rpm and speed reading but I am lazy furthermore I never remember what gear I am in. Also I was hoping with the indicator that it would find the long lost 7th gear I always look for. No luck there. And I like gadgets. How much that plays into it is anyones guess.
  4. jay956
    jay956 New Member
    just curious because ive never found myself wanting to know what gear im in. as long as im in the right one i dont care.
  5. speedpoker
    Ya I hear you but I have a hard time knowing if I am in the right one. On tours I have found myself riding for long periods of time in 5th thinking I was in 6th. Gas millage thing. Also while in 6th I often try to shift up to 7th. It makes me feel stupid. Like darn I should have known I was in 6th already!!
  6. speedpoker
    Little off topic but I feel I have been doing all the explaining and not getting any answers. If someone could explain the need for Mac computers or single speed mountain bikes that would be great.
  7. Interceptor1
    Interceptor1 New Member
    Quebec
    "It makes me feel stupid."
    Who care, I am planning to order one too. Is it difficult to install? Just plugging I guess. :biggrin:
  8. speedpoker
    As for the feeling stupid thing I just don't like to feel stupid. Its not like I at the next stop take off my helmet and go bash my head into the nearest tree 7 times or anything like that. As for the install its a bit of a pain but not too bad at all. You have to take both fairings off and locate the ECU and the plugs on the other side. Connect the plugs on the left and use the splice thing on the right to tap into ECU rpm wire. Then just rout the wires and stick the indicator on the dash. If you need any help with any of it feel free to ask.
  9. Interceptor1
    Quebec
    Tanks very much. :smile:
  10. monk69
    monk69 New Member
    Danville,Va.
    Looks good.... Did you drill a hole in the dash to mount it?.... If so is there anything to look out for on the other side, as the drill goes though?...... And what did you wire it to?...... Monk
  11. speedpoker
    Thanks, no I just pealed the cover off the sticky back and stuck it there. Seems to be on there pretty good. As for wiring it is not that bad. It has quick connectors that go right in and on the ecu side you just tap into one wire coming out of the ecu loom. The directions were pretty straight forward. The new x-type Gipro which I have is smaller than others apparently so it fits pretty well on the dash.
  12. sound wave
    sound wave New Member
    Honolulu, Hawaii
    speedpoker, did it come with instructions specific for the vfr? if so, could you please scan and post it? i was thinking of getting this too.
    thanks.
  13. Knife
    Knife Member
    Downingtown, PA 19335
    I put this on my shopping list. Thanks for the nudge!
  14. eddie cap
    eddie cap New Member
    Valley Forge, Pa
    Gear Position Indicator
    Hi All; Yes I think a gear selector indicator is a good thing,I know a few years ago the
    Suzuki GSXR came stock with one,however I am not sure if they still do. Also what
    does something like this cost? thanks ed
    P.S. I forever am trying to shift into seventh gear so I do believe it would be
    $$$ well spent!
  15. bat-stang
    bat-stang New Member
    H-Town Texas
    I like that trinket myself... sometimes when Im feeling technical I have to count down to be sure I don't stick first gear cause I thought I was in sixth and I was in fifth... Sometimes I imagine myself a racer, trying to pick perfect line, perfect, speed-- then I have to <dodge> other users of public roads and it throws me off a bit. Being able to look down and see what gear Im in would help. People choose mac because it is more creativity driven; ie musicians, web site builders, artists, think its easier to use than pc. Also, less viruses for mac, they all seem to be aimed at pc. Don't have an answer for the single speed mtb question...
  16. VFRstar
    VFRstar New Member
    Utah
    One reason I want one was an article I read. It recomended to use the "warning speed limit" to determine what gear to be in when cornering. So if it says you should take a corner at 30, you should be in third gear and use the throttle alone to slow down. I haven't tried this yet because I never know what gear I'm in.
  17. V4 Dude
    V4 Dude New Member
    Atlanta
    I liked the gear indicator on my old '85 Nighthawk 650 so I can see why someone would want to have it.
    As of the Mac, IMO they are less annoying than a Windows PC.
    As for the single speed MTB, it's the challenge and the simplicity. SS bikes make you think about conservation of momentum and have fewer components to cause problems.
    I never thought about it but a Mac and a SS mountain bike have common traits, simplicity and reliability.
  18. Echo3Niner
    Echo3Niner New Member
    Chicagoland, NW - IN
    +1 I often am not sure which gear I am in before a corner, and I try to shift into 7th also, from time to time... Must be a special shift mechanism...
    Question, is it quick? In other words, does it have a delay where it has to wait until I let out the clutch, or does it read it as you shift, even if shifting down several gears at once?
  19. sound wave
    Honolulu, Hawaii
    is there any room under the gauge pod cover to give it a clean install? if possible i would want to give it an oem look.
  20. sound wave
    Honolulu, Hawaii
    i just did this mod, so i can answer my own question... no, there is no room under the gauge pod cover. i was going to modify the cover next to the gauge pods, but it seemed that it would be covered often by the brake fluid reservoir, so i just attached mine the same way speedpoker did.
    for the bikes 06+, it just attaches to this red plug under the little cover (right meter panel) to the right of the gauge pod. all that is needed to install it is to remove that meter panel. i had my lower fairings off because i also did some other mods at the same time. here is a pic of the red connector the gi pro attaches to:
    literally a one-connector install. very simple. nothing exciting, but here is how it came packaged:
