Going shopping...
Discussion in '5th Generation 1998-2001' started by vikingGoalie, Oct 30, 2020.
  1. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    The issue with soldering up, is that I don’t have power to hand, and if I need to get in to the fuel pump or filter I have to unsolder again
    I don’t have any power in the garage where I keep the bike, and a gas powered iron would be very dangerous
    So I’m looking for a sensible high amp connector, I thought that would be good enough?
    VF1000F2F, in bits
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    Again, I'd say the Andersons are quite good, mainly if you have a square area contact greater than the original wire... slightly overdesign if that's a better way of putting it.... it will handle the current, not overheat, and they are plated to resist corrosion... contact paste will help coat them so oxidation doesn't occur.
    I used 50 amp Andersons to connect my jumper cables with 10 ga. wires, that kind of overdesign is what I mean. Max temporary current might have been 30-40 amps during a jump.
    If you are upgrading to a mofset R/R, then all the better.
