got me a 84 vf700f new member small problems
Discussion in 'Introductions' started by wesexe, Nov 27, 2011.
  1. wesexe
    wesexe New Member
    got the 84 vf 700 f only firing on two cylinders both coils test the same so dose pulse gens and cdi boxs nothing seem to be out of the norm but will not fire on all four the wires dont seem to be the reason nor the plugs them selfs any help will be appreciated
  2. tinkerinWstuff
    so are you saying you checked for spark and there is none on two cylinders?
    which two?
  3. TOE CUTTER
    Failure of two cylinders is classic CDI failure for gen 1 and 2. Do not shoot the messenger.
  4. squirrelman
    Say you tested the CDI boxes?? How ??
  5. wesexe
    wesexe New Member
    buddy of mine told me to ohm test them, i get spark on all cylinders swithched the cdi boxs and the same side dose the same thing
  6. tinkerinWstuff
    pulse generator
    mahna mahna
  7. wesexe
    wesexe New Member
    ohm tested they are where they should be leaning toward the carbs been sitting for bout a year could be gummed up
  8. tinkerinWstuff
  9. tinkerinWstuff
  10. wesexe
    wesexe New Member
    i have spark on at cylinders, but the bike has been sittin for about a year so is it possible that the front set of carbs are gummed up and the back set not
    sorry for the confusion
  11. tinkerinWstuff
    I would pull the airbox off and crank. pour a tablespoon or so of raw fuel down the rear two carbs and see if it fires. A little shot of starting fluid would work too.
    if you hear a noticeable difference, you've proven there is a problem with the fuel system.
  12. wesexe
    wesexe New Member
    i will do that and let you know thanks
  13. wesexe
    wesexe New Member
    i pulled the air box off, poured a little fuel directly into the carbs,it shut off.
    but i did notice that one of the carbs wasn't opening when the rest did.
    i then opened the carb to the same height the rest were opened and it ran better,not like it should but better.
    so i guess get the carbs rebuilt and sync ????
  14. TOE CUTTER
  15. wesexe
    wesexe New Member
    thanks toecutter very useful i will try ..
