Hello All. Just joined the forum and am a proud owner of a 1989 vfr750 fj in metallic black. As always i have looked everywhere on the net for an assembled parts diagram but to no avail. Anyone got any ideas to point me in the right direction? Also, does anyone know if the pro arm rear assembly can be fitted to my 89 fj model? Has anyone done this already? Any help would be greatly appreciated. Phil
SSS conversion Phil given a big enough hammer, almost anything can be fitted. In your case, the critical dimension is the width of the existing swinging arm in the frame. I have an extra Pro Arm in my garage; I will measure it to see the width and let you know what it is.
Hi Phil, welcome to the group. ronayers.com and bikebandit.com both have online microfiches. Not sure that is what you are looking for though.
Hi guys. thanks for the replies. on the microfiches, was more concerned about internal engine assembly and valve clearances etc. i work for the airforce so big hammers aren't a problem!!! phil
