Ground Block
Discussion in 'Mechanics Garage' started by dbuzz77, Apr 18, 2020.
  1. dbuzz77
    dbuzz77 New Member
    South Lake, Saskatchewan
    I searched but i must not be entering the right words, is there a common ground block on 6th gens? just trying to check out stuff for the new season. thanks
  2. Terry Smith
    On the 6G it is up under the nose fairing, on the 5G it is in the harness left side below the seat/sidecover.
  3. dbuzz77
    dbuzz77 New Member
    i have been in there with a flashlight with the side fairings off and i can't see where it would be
  4. Terry Smith
    Sorry mate, I had the 5G but not the 6th, but you are looking for a blue plastic block, I know its at the front of the 6G and I suspect you need to take the nose fairing off for easy access. Try searching for earth block instead of ground.
  5. dbuzz77
    dbuzz77 New Member
    I don't know where it is , i took off the front fairing and no green connector or ground block. not sure where to look now
  6. Terry Smith
  7. dbuzz77
    dbuzz77 New Member
    nothing like that there at all. i see that unit there with the plugs on it but no other cables there at all. also do you know where the frame ground that comes from the battery is?
  8. Terry Smith
    The ground connector is probably wrapped in electrical tape against the harness. Feel around for it.
    The earth connector for the 5G was bolted to the mainframe around the shock area. You should just be able to follow the earth cable from the battery negative to find it.
  9. dbuzz77
    dbuzz77 New Member
    i found the grounds it was a lot smaller than it looks in the picture and buried. picked up 0.3v by taking it off and on again. very clean. now if i could find the ground from the battery. thanks
  10. dbuzz77
    dbuzz77 New Member
    anyone found the frame ground on a 6th gen?
