Harness Connector Info
Discussion in 'Mechanics Garage' started by Expvet, Jul 26, 2024.
  1. Expvet
    Expvet New Member
    Puerto Rico
    Brooklyn, NY
    Looking to replace toasty connectors on battery harness. These come from the 30 amp fuse near the battery.
    Can anyone tell me the wire size or the connector type/model for the battery harness connectors shown in these pictures and a good place to order some quality connectors to replace them with?
  2. Totaled TL
    Totaled TL New Member
    Louisville, KY
    Try Eastern Beaver.
  3. NorcalBoy
  4. linkken
    linkken Member
    Fortine, MT
  5. mello dude
    Been working with Joe for lots of years...also awesome guy....
    But anyhoo....CycleTerminal is boss!
  6. NorcalBoy
    I would prolly upgrade that to a modern sealed connector.
  7. Expvet
    Expvet New Member
    Puerto Rico
    Brooklyn, NY
    Thanks for all the great information. Still deciding between connector based or direct soldering of the two wires. Another option is putting in a new inline fuse holder and eliminate the connector in the process. The RR and stator test fine so do not want to go the Mosfet route without needing to.
  8. Expvet
    Expvet New Member
    Puerto Rico
    Brooklyn, NY
    Now a question about the RR and stator connectors that are near the RR itself and are in good condition, I would like to remove the terminals to better clean them. Does anyone know the process to safely remove them?
  9. mello dude
  10. Expvet
    Expvet New Member
    Puerto Rico
    Brooklyn, NY
    OK, another question. This is the bonus round. I am going to install a voltage meter, specifically this one, which can be turned off.
    https://www.amazon.com/dp/B093C9H5PV?psc=1&ref=ppx_yo2ov_dt_b_product_details
    I am looking to install at the left side upper cowl where part # 7 goes as shown in attachment.
    My question is to drill the 2 inch hole in the plastic part, is it better to use a hole saw or a step drill bit?
    Same issue one would have if installing sliders.
    mello dude likes this.
  11. VFR750F3
    VFR750F3 New Member
    Mt Kisco, NY & Weeki Wachee FL
    Did you drill it yet? What did you use, and were you satisfied? I used a holesaw but a step bit may have been nicer. I think if I owned one, I'd have tried it first. Just a guess since I don't have a step bit...
  12. Expvet
    Expvet New Member
    Puerto Rico
    Brooklyn, NY
    I used a step bit and it came out very clean. Good thing about it is you can drill, stop and check until you have a perfect fit. My meter fit nice and tight.
  13. linkken
    linkken Member
    Fortine, MT
    photos?
  14. Expvet
    Expvet New Member
    Puerto Rico
    Brooklyn, NY
  15. squirrelman
  16. linkken
    linkken Member
    Fortine, MT
    you just wired that in and mounted it in the cockpit area?
  17. squirrelman
    ^^i sure did. may take some experimentation to find the best place to mount.
  18. Expvet
    Expvet New Member
    Puerto Rico
    Brooklyn, NY
    This is what the meter looks like.
    It is on the left (clutch) side inside panel as shown in an earlier post on this thread.
    Easily seen when riding, wheels are turned to left in these pictures so slightly obstructed by the grip.
    I put a rubber washer to seal it and protect the wires underneath.
    What I like is you can turn it off when you park.
  19. linkken
    linkken Member
    Fortine, MT
    good job! looks nice!!
