Having problem with a front wheel bearing
Discussion in 'Mechanics Garage' started by Boosh63, Aug 26, 2019.
  1. Boosh63
    Boosh63 Member
    Timmins, Ontario, Canada
    I had a wheel bearing catastrophically fail the other day while riding. I remove the front wheel and the left bearing just all fell apart leaving only the outer race in the wheel. I have nothing to bang on to remove it. Suggestions?
  2. Boosh63
    Boosh63 Member
    I'm not sure if this is the right way but I took a Dremel with a cutting wheel and cut into the race twice and pried it out. In my impatience I managed to score the hub a little I hope that doesn't make much of a difference.
  3. Thumbs
    Thumbs Member
    Bath(ish)
    That’s as good a way as any without a puller
    The cut won’t make any difference to the fit, you can always use a bit of Loctite for peace of mind
    When you get the new bearings ask for double lip sealed
    Boosh63 likes this.
  4. Boosh63
    Boosh63 Member
    Thanks for the tip on the type of bearings but I had already ordered from a Canadian outfit online. I don't know what they are except they were inexpensive. All Balls brand...
    Red or blue Loctite?
  5. OOTV
    OOTV Insider
    I had helped a fellow member with his rear wheel on his Buell. Similar to your situation, the bearing disintegrated while we were on a ride! We had a tough time with removal but ultimately had to do the Drexel route. There was a slight Nick in the bearing race but it didn’t impact the new bearing.
    If I’m not mistaken, All Balls have double sided sealed bearings.
    Boomtank and Boosh63 like this.
  6. squirrelman
    i'd generally AVOID 'allballs' because they supply cheap chinese garbage and are too unreliable for use as wheel bearings. for your safety use only bearings made in usa, japan, germany, sweden or switzerland.
    inexpensive bearings are ok in some places but never in wheels ! :eek:
    fink, Thumbs, ridervfr and 2 others like this.
  7. Boosh63
    Boosh63 Member
    I will consider changing them again prior to the start of next riding season.
    How many km's "should" a wheel bearing last?
  8. squirrelman
    usually need replacement by25- 35k miles.
  9. Boosh63
    Boosh63 Member
    My machine has a boat 15,000 miles on it.
  10. squirrelman
    maybe u had a seal failure that let water in ? you never used a pressure washer on the bike ?
    Boosh63 likes this.
  11. Boosh63
    Boosh63 Member
    I just bought it. Based on how clean it was I can imagine the prior owner using a power washer!
  12. ridervfr
    Belgium
    I have not replaced any of my wheel bearings on any of my street bikes eva, I don't ride through creek crossings or use power washers either. I did do my YSR50 a while back, I have a blind bearing puller from Tusk, it comes in a red blow molded case and has a range of collets along with a slide hammer (best part of the job.) Anyway, we dodged a Cat5 hurricane so FTW. :mech: Hi ice-hunchin :wave:
  13. squirrelman
    i just had a front wheel bearing failure on my Yamaha Radian beater bike @ 22,000 miles. it was making noise, and then the speedo drive quit.
    ridervfr likes this.
  14. ridervfr
    Belgium
    WOW! What a blast from the past, I remember the old Radian back when I had my Kawasaki ZL600, what a pita. Remember the Fazer had some funky gold accents, matter of fact all their bikes wore some gold, guess that was the style back then.
  15. Rsparky
    Rsparky New Member
    This is good to see. I'm planning some wheel "paint", so will get new bearings for the process.
  16. fink
    fink Member
    Had a bearing fail once and the balls escaped. What I did was to gather them up and screwed in a self tapper the correct width to take up the
    space between the bearings and was able to drift out as per normal.
    Thumbs likes this.
  17. Rsparky
    Rsparky New Member
    Sounds like a bad time fink.
    Hopefully the screenshot attached. I just want to make sure. Buying oem. Does honda pack both bearings in one box? Thus why bikebandit says you only need 1 per assembly?
  18. fink
    fink Member
    I knew the bearing was away. It was while I was in the process of replacing the shot bearings
  19. Darth Vader
    Darth Vader New Member
    melton mowbray
    Yes they come in pairs
  20. squirrelman
    @ $11 each, i doubt you are buying quality bits made in japan or someplace with high standards. Honda OEM replacement parts come in familiar honda packaging, the best way to see you have the genuine stuff.
    one sign that the bikebandit parts aRE not OEM is that they sell an oil seal for the bearings while honda OEM comes with oil seals alreAdy in place.
