having some wierd bike issues
Discussion in '1st & 2nd Generation 1983-1989' started by matt1986vf500f, Aug 27, 2009.
  1. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    I believe it's now time to make the call, this thread is officially....
    THREAD JACKED
    :ninja:
    #81
  2. jporter12
    jporter12 New Member
    Johnstown, Ohio
    Threadjacked, yeah. So how is the bike running now?
    #82
  3. DKC'sVFR
    DKC'sVFR New Member
    Riverside,CA, North America, The Earth
    While waitin',nothin'wrong with discussin' compression.
    Great discussion. :thumbsup: I think it's been a great education for everybody, myself included. I've put the Thermo text back on the shelf. I see Jamie's point regarding the fact that we are dealing with a cold engine and making assumptions that we are not adding heat when we squeeze that cold air mixture. The whole discussion of valve overlap, ram effects and scavenging is facinating and I want to thank GreyVf750f for those points. I was trying to touch on those in mentioning the assumption that air had no mass or momentum in the adiabatic case. But I stand corrected by Jamie’s realization that I was describing 'operating pressure' and not 'cold pressure testing'. Still the whole “compression pressure” discussion is cogent and not that far off from the subject at hand. I mean that no matter how hard you try to get the carbs perfect they ain't gonna work if your "pump done broke". Now we all need to agree that Matt's Vf500 is going to have to have all cylinders within 10% and above 140 psi(?). More than likely around 175 psi. I don’t have a factory manual for the Vf500, so maybe someone with a factory manual could read us chapter and verse of what Mr. Honda says is acceptable. I do have a Clymers Vf500 manual and Mr. Clymer says Compression on a Vf 500 should be between 142-199 psi.
    Sooo, Matt’ew,me boyo, give us a t’rill an’ tell us all if ye’ would, what the cylinder pressures are before ye’ go out to play wid' your toy made new.
    Meanwhile, what we are waiting for is the result of rebuilding Matt's 86 Vf500f carbs . There was necessarily going to be a dead spot while he fought the good fight getting those fresh Kaitin 31A's dialed in. He has to work too, so it will take some time for him to sort it out. In the meantime I don't think a discussion/argument :argue: on how to calculate cylinder pressure at low piston speeds and cold temperatures is a bad way to pass the time. :smile: And it was a great reminder that we might want to make sure that Matt's Vf 500 is pumping like it should before he tests out his virgin Kaitins. :smile:
    DKC
    #83
  4. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    not yet still cleaning the tank things have been going slow wiht work and then going to see my boys has'nt left much time to work on the bike
    #84
  5. DKC'sVFR
    DKC'sVFR New Member
    Not a problem boy'o. That's what arguing about how to "calculate cold cylinder compression pressure" is for. Take care of your work and your kid's first. The bike will fit itself in in its own time.
    #85
  6. GeorgiaRider
    GeorgiaRider New Member
    Marietta, GA (Atlanta)
    By all means Matt, take care of those two new youngun's first.
    Priorities in life are the ones you love, not the things you love! Things are just 'things'!
    Without the ones you love in your life, all the 'things' in the world are just useless junk.
    #86
  7. jporter12
    Johnstown, Ohio
    Amen to that one!
    Didn't realize you had a couple new guys. Take care of all the family stuff first, as if you really need me to tell ya that!
    #87
  8. DKC'sVFR
    DKC'sVFR New Member
    How's the weather been treating you?
    Had to drop by to tell you that there is another guy complaining that his Vf 500 has surging problems. His thread is 'Cam lobe flattening '85 Vf 500' thread started by 'TinkerinWstuff', Wish you could get into the discussion regarding your outcome. Hope you get the bike on the pavement before winter shuts off riding. And, by the way, how is the wife treating you? Miss your substitute. You need to take her for a fast ride?
    #88
  9. slowbird
    slowbird Member
    Toronto, Ontario.
    Hmmmm....I hope that isn't Matt's issue.
    You got the bike running yet?
    #89
  10. matt1986vf500f
    i should have it running by this weekend and give y'all the ride report i doubt thats whats going on with my bike (lobe flatting) but if it is or does i've already called dave dodge up and will be sending the motor off next winter for a extreme motor build the goal is 90hp on 93 octane :thumbsup:
    #90
  11. JamieDaugherty
    Fort Wayne, IN
    DKC - I've been working really closely with Matt on his bike. I can tell you that the cams are not his problem. When the rockers go bad it's accompanyied by quite a bit of ticking and knocking sounds - he would have mentioned that. I think TinkerinWStuff has a few things going on, his bike was quite a bit more neglected than Matt's.
    #91
  12. matt1986vf500f
    amen to that brotha :biggrin:
    #92
  13. NorcalBoy
    Don't be too surprised if you do not see an improvement, or that it actually makes less peak hp, with the use of 110 octane fuel. Octane is simply a rating of a fuel’s ability to resist detonation and/or preignition. It is possible to "over octane" your engine and it will actually run worse than it does on pump gas. Give the VP U4.2 a try and I'm sure you will be pleased. In my experience this fuel will get you a gain somewhere in the ballpark of 5%......of course 5% of 29.8 isn't gonna make you smile that much....but it is realistic to see a 1-1.5 peak hp increase. The best I have gotten is a 6.5% increase in peak hp, but 6.5% of anything over a 100 peak hp is substantial. :biggrin:
    #93
  14. tinkerinWstuff
    I looked at this thread periodically but the thesis on compression ratios got deeper than I cared to follow.
    My surging issues aren't related to the cam, the surging is carburation. And unfortunately, there were a slew of things wrong. The air filter was CLOGGED. The new one came in from Honda after I tore the bike down to deal with the cams so I won't know if that was the direct and only cause of the surging.
    The carb boots were badly cracked and could easily have leaked some vacuum. Those parts also came in with the air filter so how much they are related to the problem is unknown.
    The bike did not run with gelled gas in the carb passages when I bought it. So there are a lot of things to verify with a fine tooth comb (or single strand of copper wire) to make sure everything is cleaned out. Need to verify consistent float height and needle/seat seal as cylinders 1 & 2 were flooding out after shutdown.
    Lastly, the carbs weren't balanced (which would have been pointless with the flattened cam) and the bike has California emissions and vacuum crap that could complicate issues...
    So in closing, I think my problems are seperate of Matt's but I'm still waiting to hear how that beastie runs. I too hope to have mine back together and firing on all fours this weekend.
    #94
  15. JamieDaugherty
    Fort Wayne, IN
    Surging is almost always a problem with the carbs. That's where Matt's problems were coming from too I'm pretty sure.
    In fact, one of my 500's has been suffering from the same thing recently. It looks like the sync is to blame there, I just haven't had the time to get it sorted out yet.
    #95
  16. tinkerinWstuff
    Rebounding from this flu is taking forever...
    I got my motor completely back in tonight (exhaust, wiring, cooling) from the cam issue. Now all that's left is to tear into the carbs, again. I'll tackle that tomorrow and since the wife is going out of town, I have all night to spend in the garage.
    Here's what has me a little baffled. I know my bike was flooding out after I'd turn it off hot. So the couple of times I rode it, I would turn the gas off and wait until the motor started to stumble before turning off the key.
    This seemed to help. But the baffling part is that when I'd turn the key on, the fuel system appeared to build and hold pressure (fuel pump would deadhead). If the needle and seat aren't sealing or the floats are sunk, I wouldn't expect the system to hold pressure.
    So the last time I turned the bike off (before pulling the motor) I shut the gas off, waited for the motor to stumble and shut off the bike.
    -pulled the carbs off the next day I think
    -and found cylinders 1 and 2 with standing fuel on top of the intake valves.
    Since I ran the motor with the fuel off until it stumbled, I don't see how there could be that much fuel anywhere in the system to suddenly pool on top of the valves.
    #96
  17. matt1986vf500f
    very interesting you got me now i want to know whats causing that
    #97
  18. NorcalBoy
    Surging can be caused by a few things, but the most common are carb related. In my experience, which is like talking to yourself when it comes to forums, is usually caused by a lean condition which results in increased rpm's even though, the throttle is held in a constant state. The surging is the result of intake vacuum/velocity fluctuation. A lean condition can be associated, with inadequate fuel supply, an air leak ( internal or external to the carburetor), an internal carburetor jetting issue (i.e. inability to adequately provide enough fuel to the intake airstream - carb pilot, needle or main jet flow issue reasulting in a lean condition, depending on which circuit is being employed at the time of the surging) or poor ignition performance (i.e. timing advance/retard issue). To troubleshoot such an issue via the internet is equivalent to grasping at straws. Systematically narrow down the possible causes until a solution is reached. There are no free lunches.
    #98
  19. DKC'sVFR
    DKC'sVFR New Member
    Just thought you and 'Tinkerin' might help each other
    If you read what I wrote I never suggested or implied that Matt had cam/follower issues. I was putting forth the "surging" issue both Matt and 'Tinkerin' complained about as the reason they might gain some advantage from contributing and involving themselves in each others threads. You are conflating the fact that I gave Matt the title of "Tinkerin's" thread (something 'flattening cam's' something something) with my suggesting that Matt somehow had cam problems. I just wanted the two of them to maybe gain from the coincidental coterminous "surging" issue. And for my money I place a higher causal value on the missing "adjustment springs" that I think Jamie had to mail to Matt because his were missing after the dealer installed his jet kit. Strangely coincidental that they went missing when the surging started to become a problem??? But then, who's to say what the root cause of Matt's surging was after having shot gunned the Carbs with a complete rebuild (by Squirrelman??) and who knows what else?
    Any whoo, I'm just as curious about the outcome of Matt's adventure (misadventure???) with 'surge control' as the rest of you. I also still want to know what kind of mileage he gets with his Keitin 31's. Similarly, I think that 'Tinkering' could gain from what Matt has learned/been taught along the way. And that Tinkerin is probably in the best position to offer advice considering that he is figuring out his way around the 'surging' problem even as we sit here reading and writing to each other.
    So, in closing I'd like you all to know that my '84 Vf 500c got 45 mpg driving at mostly 80 to 90 MPH ("Everyone was driving that fast, Officer") on LA's freeways last weekend. So I have a feeling that my aged romper would be gettin' near 50 mpg if I were straight driving the freeways on it from fill up to fill up, even with those fat Keitin 59's on it. And that extends my cruising range out to 130 miles and better :thumbsup:.
    #99
  20. tinkerinWstuff
    Well Matt, how are ya coming? Mine was back running late last night. I still need to sync the carbs this afternoon but initially things seem to be greatly improved.
    I found the passage from the jet in the bowl (the one that doesn't come out) up to the base of the diaphram was partially plugged in three carbs. The floats were also set lean, which would make sense for my altitude but I set them back to factory spec anyway.
    My used pipes from the salvage yard aren't much to look at but they sure are quieter without rust holes in the bottom and I'm sure the added back pressure helps.
    After I get the carbs sync'd, I'll put the screws to her and see how it does. It's supposed to be in the mid to upper 60's tomorrow and the wife is out of town so I'll have the whole day to ride.
    It also didn't seem to flood out after shutdown last night. I'm just waiting to call it a victory before running it a few more times.
