Headlights on off switch?
Discussion in '6th Generation 2002-2013' started by Hans Olsson, Jun 11, 2019.
  1. Hans Olsson
    Hans Olsson New Member
    Sweden
    Eskilstuna Sweden.
    My bike does not have one.
    When the key is in the "run" position the headlights is on.
    There is position/parking lights in the front,but they can not be on without the headlights?
    Does it seem ok to you? 2003 model.
    Hans.
  2. jstehman
    jstehman New Member
    My headlights are on when the ignition is keyed on.
    Hi beams need the rocker switch to be activated.
    US model
    Sent from my SM-N950U using Tapatalk
    Hans Olsson likes this.
  3. fink
    fink Insider
    Yes, Honda Changed the right bar switches in 2003 so that it was lights on all the time. This was across most of the model ranges.
  4. Hans Olsson
    Sweden
    Eskilstuna Sweden.
    Thank you!
  5. ciprinakos
    ciprinakos New Member
    Romania
    Constanta
    Both the running & high beams are supplied through separate relays mounted on the front subframe between the headlights - you need to remive the entire front cowl to get access. I hahe a switch mounted on the low power/control circuit. Having the headlights running when trying to start the bike on a low battery sucks!
  6. Hans Olsson
    Sweden
    Eskilstuna Sweden.
    Good idea Ciprinakos,thank you.
