Heat shield for soft luggage
Discussion in '7th Generation 2010-Present' started by bikeman1945, Nov 12, 2009.
  1. bikeman1945
    bikeman1945 New Member
    Atlanta, GA
    I have an '07 RWB Interceptor and would like to use my RKA soft saddle bags with it occassionally. I woud like to find some kind of heat shield material that I can attach to the mufflers / muffler shields so that I don;t melt the bags. I don't want to attach the heat shiled material directly tot eh bags since I use these bags on other bikes. I also have another bike with hard bags, so I'm not really interested in buying a set of the hard bags for the Interceptor. Do any of you have experience with any kind of heat shield device that would work as I have described? Thanks.
  2. Pliskin
    Pliskin New Member
    Morris County, New Jersey
  3. Marrib
    Marrib Insider
    Phx, AZ
  4. Dudealicious
    Dudealicious New Member
    Smoggy but always sunny, LA
    Here's how i got around melting my bags
    [Link]
  5. 34468 Randy
    Do you have the factory pipes still. Those shields are sufficient to protect soft bags
  6. bitterpil
    bitterpil New Member
    Northern Virginia
    +1 on what randy said.
    If you still don't feel comfortable. Go to Jeggs and get the adhesive backed heat shield material.
    Heat Shield & Insulation Safety <<--link
  7. bikeman1945
    Atlanta, GA
    Randy, I do have the stock heat shields and mufflers but I was told the bags would melt w/o more protection??
  8. 34468 Randy
    By all means, go with what you are comfortable with. FYI, in April I put on a brand new set or Cortech soft bags on my 6th gen with stock pipes complete with factory shield. I drove from home, to Atascadero, Ca, then to Victorville Ca and back home. Over 3200 miles in 9 days. The foam rubber anti scratch padding became warm to be sure but came no where close to burning or melting. But if you ride in hot climates, then of course this may be different, but I don't think so.
    Marribs configuration will work for you. Lgn001 aslo has this configuration for his 6th gen as well and he swears by it.
  9. bikeman1945
    Atlanta, GA
    THanks, I'm going to try it w/o any other shield first and see if that works.
  10. hondajt
    hondajt New Member
    springboro, oh 45066
    isn't this in the wrong section?
  11. NOLA VFR
    NOLA VFR New Member
    New Orleans
    I have the Cortec Sport bags. They have not melted. I ride in south Louisiana/Mississippi.
  12. 34468 Randy
    Well gaaaawleeey. I think you are right. I just answered a new thread as I saw it show up. DOn't know if it is worth the mods changing this. But seeing as I am not the owner of the thread, I will do nothing....well....little anyways.
  13. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
