Heated hand grips question...
Discussion in 'Mechanics Garage' started by derstuka, Jan 29, 2007.
  1. dietDrThunder
    dietDrThunder New Member
    Nashville, TN
    +1
    I've been using these on various bikes for years, and they work great.
    For the guy who mentioned the right one getting hotter...that's because the right one is insulated by the throttle tube, while the left one is in direct contact with the alum. bar (aluminum is a fine conductor if heat ).
  2. aaastone
    aaastone New Member
    NH
    +1
    I took the above advice and just installed the Ergo-2 grips on my 2000. I have been very pleased. Installation took about an hour, figuring out where to run the lines and soldering the connections. I tapped off from my license plate light for the power. The were tight enough without epoxy that I didn't glue them down. I used a couple of 14 ga copper wires as spacers to tighten the clutch side a bit. I can still force a rotation, but they feel very secure to me. YMMV.
    I installed the switch in the little piece of plastic that extends up under the mirror (left side). I had to bend the tabs slightly to fit, but it worked out to be clean spot to put it.
    The grips themselves are thicker than the stock ones I removed, but they are comfortable.
    The first cold morning I turned them on, I thought "Why didn't I do this years ago?" Here in NH it's already starting to frost at night, so these grips will definitely help extend my season a bit.
  3. Crashy
    Crashy New Member
    Is there a preferred place to pull power for heated grips on a 5th Gen?
  4. soundmaster31
    soundmaster31 New Member
    Jackson, Michigan
    Mine is tapped into the license plate light wire.
  5. Crashy
    Crashy New Member
    Thanks Soundmaster, I'll check it out.
  6. soundmaster31
    Jackson, Michigan
    You can always run your own wire to the battery to make sure your wire gauge is large enough for the current draw...
  7. Crashy
    Crashy New Member
    I want it to switch of when the bike is not running.
  8. olivino
    olivino New Member
    New York
    I am researching heated grips and saw this thread. Has anyone installed heated grips with Throttlemiester cruise control? I am just wondering if its like any other bar end ?
  9. Megatronousprime
    Megatronousprime New Member
    New Jersey
    right grip hotter than left
    I found a great solution to this problem--on the left grip, I installed the heating element right on top of the stock grip and put the heat shrink on top of that--works great!! Don't do this on the throttle side because the heat shrink material is not "grippy" enuff.
  10. Outboard John
    Outboard John New Member
    Escondido, Ca.
    Another blast from the past, seven year thread jump!
  11. Dead Eye Dick AKA Carpy
    Dead Eye Dick AKA Carpy New Member
    Chill Out City
    I use Honda OEM heated grips, they are fantastic. 6 heat settings and they go into standby mode when you stop, then repower when you start moving again. They have been on the bike since before I bought it (4 years ago) and not a moment's grief
  12. A.M
    A.M Moderator Staff Member
    Thank you for bringing this back up!
    I just had lunch with a friend today and the topic of heated grips came up. He has an extra set of heated grips that he is willing to sell me, but they seem like a pain to put on... some business about threading the wires through the handlebars and having to drill into the bars as well.
    I was also talking to someone else today about this. Seems HotGrips Ergo2 has positive reviews. Derstuka, what did you end up doing?
  13. NorcalBoy
    I prefer this type https://www.amazon.com/Heat-Demon-External-Motorcycle-210019RR/dp/B001AWRCJO
    Super easy to install and you don't get the "fat" grip effect of grips with the heating elements molded in, i.e. Honda. With these, the grip thickness stays almost exactly the same and you can use any grips you want.....and you can change the grips without messing around with the heating elements. With a shot of hairspray, any grip will slide right over them and a couple safety wire wraps will keep them there.
