Help! Damn thing did run!!
Discussion in '1st & 2nd Generation 1983-1989' started by Louis Robinson, May 9, 2021.
  1. squirrelman
    i see that your choke lever isn't hooked up but ought to be. riders often claim their carbs are clean when they aren't. idle speed adjusting screw must be set right, not too much or too little. dija check for sparks on all 4 cylinders and for low battery voltage ? idle mixture screws should be set at between 1 1/2 and 2 3/4 turns out. inspect sparkplugs for color and gap. try jumping the battery with one from a car (not running).
  2. Louis Robinson
    Louis Robinson New Member
    Yes all 4 cylinders have nice bright spark!
    It ran before with the choke not hooked up!
  3. squirrelman
    despite what you say, the choke must be working to start properly unless the bike is already warmed up.
  4. straycat
    I'd say Colddevil and Squirrelman are correct. But will add my 2 cents...
    1) If it runs when you put fuel down the carb throats, then for some reason you have a fuel supply issue
    2) If your feeding the Carb directly from an auxiliary tank bypassing the fuel pump, and it still wont start and run then you either need to reconnect your choke or have another look at how clean those carbs really are
    3) When you cleaned the carbs did you remove and clean ALL the jets (including the slow speed Idle jets - -the ones with the flute holes in them). Did you remove the mix screws and blow out all the passageways ?, How far did you disassemble each carb ? Did you avoid spraying carb cleaner into the carb with while rubber diaphragms were still installed ? (it will turn them to goo).
    Diving Pete likes this.
  5. Louis Robinson
    Guess i will order a carb kit and pull it completely apart and put all new in! Thanks for the help
    I will update when something different happens
  6. straycat
    You may not need "all new" you can try just cleaning all the jets, needles, seats, passages etc.
  7. squirrelman
    ^^ he's right. just clean them by poking a steel wire (,010") through idle jets and blowing out mixture screw passages.
    dija check the float level adjustments ?
    new carb kits won't always cure things and may be a waste. again, you're just throwing parts at it and hoping for the best.
  8. Louis Robinson
    Did that once! Pulled jets out and clean them! How do u check float level?
  9. Louis Robinson
    Guess i will pull carbs off again tomorrow!
  10. squirrelman
    you start by reading the honda service manual first thing. :oops: without studying that you're sure to screw things up and make no progress. probably need no changes to float level adjustment if it ran ok before, and it's not something to fool with unless you understand it completely.
  11. Louis Robinson
    Hey anyone havea idea on how to get a broken jet out? Mine broke, now it only has one half of the flat screw head left! Any idea??? It's the low side jet by the way!
  12. straycat
    an EZ-OUT thread extractor, a very small one. You can get them in a set of various sizes
  13. Diving Pete
    And use HEAT...
  14. Louis Robinson
    It's a live!!!!!! Waa a clogged jet
  15. Diving Pete
    Don't worry, once you start working on these you get to figure out the carbs fairly fast ... LOL
  16. squirrelman
    ........but you claimed the carbs were clean :potstirrer1:
    TOE CUTTER likes this.
  17. Louis Robinson
    Must have missed one jet!!!
  18. straycat
    Seems odd that one clogged jet would cause the bike to not start at all, normally you'd get one cyl not running but the other 3 would be fine. Did you happen to hook the choke back up as well ?
  19. squirrelman
    ^^^^& ya know, i was thinkin the same, that one clogged jet wouldn't fixit.
