Help!! How does one identify when a piston is in the compression stroke?
Discussion in 'Mechanics Garage' started by jaimev34, Dec 13, 2009.
  1. vfourbear
    vfourbear New Member
    Cincinnati
    I know its been mentioned, but please turn the engine over slowly by hand as a final check. Very important. Dont ask how I know. :biggrin:
  2. Joey_Dude
    Joey_Dude Member
    North Georgia
    Hmm... I've always replaced the o-rings and gaskets. They're not that expensive and it's not worth risking the engine IMO.
  3. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Word. Better safe than sorry. What about the sealing washers? Did you install new ones?
    Hey Bear, who are those hot chicks on your avatar? Do you know if they're available.
  4. kingsley
    kingsley New Member
    Osoyoos, B.C. Canada
    Here's a few pictures of my project.
    Rads dropped for front access.
    Tank lifted for rear access. Air box not disturbed.
    The source of all that whinning !!!!
    Crankshaft index at "3T", cam shaft indexes facing outwards. Ready to check #3 valves. The cam lobes look like they follow the index marks.
    Totally unrelated - X-mas bling: a new Gold Chain.:wink:
    (thanks to chomper for lending me his chain rivetor)
  5. Joey_Dude
    Joey_Dude Member
    North Georgia
    Yup, whatever the service manual states to replace I replaced. BTW, when you're done assembling the bike I highly recommend doing a starter valve sync just to get the bike running in finely tuned state.
    Here's a thread on more info for this: http://vfrworld.com/forums/fifth-generation-1998-2001/18343-question-about-starter-valves-5th-gen.html
    It's actually pretty fun and easy to do, you just have to adjust some tuning screws, the whole thing takes me about a half hour to do.
  6. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Thanks again, Joey.
  7. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Kingsley: Are you going to post some photos of the cam removal and adjustment? How many did you have out of spec?
    When you remove the cam holders they may be a bit hard to take off because they are stuck to the head (at least mine were). Even though all the bolts were unscrewed, I had to carefully pry the holders loose, possible because they had never been removed before and from the pressure.
  8. kingsley
    kingsley New Member
    I'll take some pictures when I do it. Not in a big rush as I won't be on the road for a couple of months, anyway.
    Carefull when torquing those bolts, I read on the web somewhere that people have stripped the threads.
    My 3/8" torque wrench is rated 10 - 80 ft/lbs. I think these cam holder bolts are only 9 ft/lbs. I may look at getting a little 1/4" torque wrench. I once broke a clutch plate bolt off with my wrench as it not too accurate at the low settings.
    Easy does it.
  9. kingsley
    kingsley New Member
    I only have one intake to deal with its 0.002" under min. spec. at 0.003" (cyl #3, outboard)
    Easy does it.
  10. vfourbear
    Cincinnati
    Available for what brother? I'm thinking unless it's to eat dinner at the buffet no....
  11. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Before I assemble the motor, I'm going to buy a torque wrench for the lower end of the spectrum. My 3/8-incher is for torques above 10 also.
  12. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    I was thinking about Soup Plantation or Golden Corral.
  13. Maggot
    Maggot New Member
    Park Ridge, IL
    I bought a 1/4" clicker type torque wrench at Harbor freight for 20 bucks! I know it is cheap Chinese stuff but I figure a cheap torque wrench is better than guessing at the torque. I think the spec's are +/- 6% so at 10 ft.lbs that's 9.4 to 10.6 foot lbs. close enough! I think it is marked in in/lbs (20 to 240 in/lbs.) so you have to devide by 12 to get ft/lbs. The few times I used it, it worked great and at that price it was worth the purchase!
  14. squirrelman
    On a clicker, after use and during storage you should back down the setting to minimum to help the calibration remain accurate, dija know??
    Off topic? sorry.....
  15. Maggot
    Maggot New Member
    Park Ridge, IL
    Yes I did! But thanks anyway, it is an easy thing to forget when focused on an assembly project.
  16. dizzy
    dizzy New Member
    MN
    Nice clear pictures Kingsley. Seeing them reminds me of a couple more things about the cam holders.
    They fit really tight on the positioning dowels, I think that's why they're sticky. When you pry on them..be VERY careful. Allow them to come off as evenly as possible, and keep track of the dowel pins...something you don't want to be dropping down the cam chain tunnel.
    The final torque is important...but just as important is to torque them evenly. Since you will be opening a valve on the adjacent cylinder, the cam covers don't want to go on evenly. Tighten each bolt a few turns at a time until the cover is completely seated, then do your torquing.
    A magnet works good for removing the lifters when it comes time. If they go in crooked they will bind...don't force 'em. A micrometer can come in handy for measuring the shims as occasionally the numbers are wore off. The lifter, bore clearance is tight...so all it takes is ONE little piece of dirt to make them stick when you start the engine. And of course it WILL cause interference with the piston and bend a valve. Be VERY clean.
  17. vfourbear
    Cincinnati
    yep, I knew I had seen them somewhere before
  18. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Molybdenum Disulfide Oil??
    Have any of you procured this lubricant and used it when reinstalling the cam holders????
    The manual calls for its use on the application, but I don't know how readily available it is. I called a shop today and I don't think the guy knew what I was talking about.
  19. Joey_Dude
    Joey_Dude Member
    North Georgia
    I hope that shop isn't the Honda dealership. :crazy: Anyway, this link is a sample molybdenum disulfide oil: Pro Honda HP4M 4-Stroke Motor Oil 10W-40 32 oz. | Rocky Mountain ATV/MC
    And yes, I used this oil on the camshafts. It's not that expensive and I'm not risking the camshafts burning up just to save 10 bucks.
  20. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Joey, I hope you didn't use something like this as this is motor oil. What the manual directs one to use, which I found out after going to a few shops, is engine assembly lube, similar to grease in a sense. It should contain Molybdenum disulfide as an ingredient, and is used for metal on metal applications. You apply it to the cam journals, whereas the sample you provided would be poured into the crankcase to lubricate the engine parts and clutch like conventional motor oil.
    Here is an example of engine assembly lube from the website you provided: http://www.rockymountainatvmc.com/p...itle=Chemicals&webCatId=23&prodFamilyId=25857
    Thanks for the reply.
