Help me identify this shock?
Discussion in 'General VFR Discussions' started by hank.sd, Nov 15, 2022.
  1. hank.sd
    hank.sd New Member
    South Dakota
    Hey all,
    Doing some garage cleanout, and I have this VFR shock.
    I think its an Ohlins, at least the spring is, although the body has a Racetech sticker.
    I believe its for a Gen 3 VFR.
    I plan to sell it, if anyone here is interested also.
    NOT a Gen 3. Or 4 for that matter. Or 5. Or 6.
    Looks more like a late model stock CBR shock. It is NOT an Ohlins shock.
  3. hank.sd
    hank.sd New Member
    South Dakota
    Hmm, I wonder what the heck brand it is. Measures around 325-328mm eye to eye, which as far as VFRs go would mean its a gen 4 from what I can gather.
    It sure looks like a stock Honda shock with an Ohlins spring on it. And someone plastered Racetech stickers on the body. Maybe it has Race Tech Valving in it?
    There is not a stock VFR shock that has an attached reservoir like that.
  5. hank.sd
    hank.sd New Member
    South Dakota
    Ah, I bet you're right. It's fully adjustable, has compression and rebound adjusters (one on top, one on the bottom) but just the ramp style preload adjuster.
    I thought I had something good, haha!
    That bottom black collar looks possibly custom to accommodate a shorter than stock spring.
    02 - 06 RC51 (RVT1000R) shock with custom spacer for Ohlins spring.
  8. hank.sd
    hank.sd New Member
    South Dakota
    Ah, that makes sense. Thank you!
    This came with a lot of RC51 parts I bought a few years back, but was told the shock came from a VFR... I never did the project so they just collected dust.
    I have SP2 forks so it would make sense this is an SP2 shock.
  9. hank.sd
    hank.sd New Member
    South Dakota
    Yes, that's absolutely what it is.. Great eye!
    Captain 80s likes this.
