Help Synching Carbs
Discussion in 'Mechanics Garage' started by daveyto, Mar 15, 2010.
  1. daveyto
    daveyto New Member
    Scarborough, Canada
    Can Someone tell me where to connect the carb sync gauges on an 1991 vfr 750f?
    Also what the procedure is to do a carb sync would help tremendously as well.
    Thanks,
    Dave
    Study the service manual you downloaded from VFRD........it's all explained along with clear photos.
  3. daveyto
    daveyto New Member
    Scarborough, Canada
    Squirrel,
    ...Actually its not.The Manual refers to.. the Common Service Manual but I can't make out any pics in the Common Service Manual.
    Thanks,
    Dave
  4. crustyrider
    crustyrider New Member
    North Country, New York
    I stole this from Motorcycle Repair: VFR 700 INTERCEPTOR, internal combustion engines, vacuum leaks
    Synchronization: This is a fine adjustment performed usually and preferably with the carbs installed and the engine running. The unusual part is performed with gauged wire with the carbs on the work bench. Carburetor synchronizing balances Venturi vacuum at the exhaust side of each carburetor, resulting with smooth idling and optimized performance at all throttle openings. Synchronization is checked using a set of gauges which are either air vacuum type or liquid mercury type. The gauges are connected to vacuum ports on the intake manifolds via nipple tubes or if sealed with screws, sync gauge adapters will be needed. With the engine running at temperature, and with a fan or means of forced convection aimed onto the engine, the carbs fuel screws and idle are adjusted, then the synchronization is adjusted via adjustment screws on the carbs. A reserve fuel tank is recommended for convenience of accessing carbs during this procedure. See gauge instructions and repair manuals for detailed use of synchronization gauges.
    http://vfrworld.com/photos/showphoto.php/photo/6520/title/86-87-vfr-carb-sync-points/cat/2
  5. daveyto
    daveyto New Member
    Scarborough, Canada
    crustyrider...thank you
    Can you tell me some more info....so the gauges are connected to the screws in the manifold...then the slotted screw on the side of each carb is adjusted...??
    It seems logical...but I can remember ...I have not synched carbs in over 20 years (don't laugh)
  6. TOE CUTTER
    The screw's are in the valley dead center of the carbs. Two in the rear and one in the front. The adapters screw into the head (memory may serve me wrong on this) two phillips screws on the left side of the engine and the right may or may not have emissions hoses in the ports on the right side. The right rear is a bit of a bitch to get to.
  7. captb
    captb New Member
    here's a vid that may help, all bikes are done the same way except for adjusters and vac line fittings are a little different.
    YouTube - carb balance
  8. TTavenierIII
    TTavenierIII New Member
    Kissimmee, Fl
    where can i get a carb tune pro from?
  9. TOE CUTTER
  10. squirrelman
    Synch is no fun on these bikes, trying to find a small screw with the tip of a screwdriver from the bottom up, in a narrow, hot , darkish place!!
  11. daveyto
    daveyto New Member
    Scarborough, Canada
    I think theres a site you can buy it for $100...its from england but theres stuff on ebay that can do it for less than half..
  12. daveyto
    daveyto New Member
    Scarborough, Canada
    I think i have seen a philips screw on the rear two carbs...i'll check it out when it stops friggin raining here.
    regards
  13. TOE CUTTER
    7mm socket should fit as well and tends to work a little better because you can turn the screws without putting pressure on them, and it is best to wear gloves because it does get HOT.
  14. daveyto
    daveyto New Member
    Scarborough, Canada
    Are we talking about the same thing? I only see a Philips screw between the carb and head????
    Do you have a pic to illustrate what I should be looking at as I don't see a 7mm bolt.
    thanks
