help with problem! losing power......
Discussion in '5th Generation 1998-2001' started by Markvfr800, Jan 21, 2015.
  1. maxredline
    maxredline New Member
    West Coast
    My bike died and couple of times coming home from a long trip. It did start up again thank god. It would just bog and quit.
    Before hand I had a FI light come on and flicker and seemed to stop when I applied the rear break. After time the FI light stayed on.
    I ended up buying a new R/R and VFRness harness which beefs up the positive and negative side of the charging.
    Then I removed the orange cover to the ground block and soldered it together. Finally I cut the 2 grounds to the EGU and connected them directly to the frames ground.
    Everything works awesome now.
  2. Markvfr800
    Markvfr800 New Member
    New mosfet r/r fitted and job done on orange block, no problems anymore, for now!
    Thanks all for suggestions etc
