Here's a new guy moment at which you might laugh...
Discussion in 'General VFR Discussions' started by PuCaudata, Mar 24, 2008.
  1. PuCaudata
    PuCaudata New Member
    Great Falls, Montana
    Try placing most of your weight on the center-stand lever. It's disconcerting to do this the first time...you'll feel like you're compromising balance. Once you get most of your weight on that lever, it'll go up no problem.
    For the record, I posted this for two reasons: 1)I laughed at myself and wanted to share the laughter with my forum buddies and 2)to prevent someone from playing "musical bike" in their garage with their VFR. I'm glad if it helped even one person. :smile:
  2. PuCaudata
    Kinky! Viagra's a wonderful thing, eh?:biggrin:
  3. Nungboy
    Nungboy New Member
    Tucson, AZ
    That is what is great about this forum...we all help each other...
    And yeah, I know (intellectually) it is the key (weight on the foot tab) but as others say, it is getting the balance of pressures just right a few times and convincing the body how to get it right...then one has no more troubles. Muscle memory and all that...
    (And I have rolled the bike several times doing the chain lube musical chairs thing...especially with the old Kawa that didn't have a center stand)
    Thanks again!
  4. Nitrousva
    Nitrousva New Member
    Richmond
    I miss my center stand, I had to take it off for the left side exhaust install. But I do have the rear stand, although it's not as easy as the center stand.
    Thanks for the chuckle.
    Robert
  5. sloan
    sloan New Member
    NW Houston, TX
    That right there is the key. "Weight on the center stand". Your hands are almost exclusively for balance. With your right foot on the lever, push the bike upright until both "feet" of the stand touch (again, a little scary at first), then stand on the lever and it goes right up.
    A while back I watched a little 140 pound dude show a 300 pound gold wing owner how to put the 'wing on the stand. The big guy just sat there shaking his head. I was laughing ss the small guy walked by me and said, "It's all in the right foot. If you're working hard, you're doing it wrong!" :smile: I'm glad I saw him do it too, because later we got an ST1300 (before the VFR) and it's 700 pounds to pop up on the stand. Of course my buddy with the BMW K1200LT just grins as he presses a switch and the bike puts itself on the stand!
  6. Gatekeeper
    Gatekeeper New Member
    After putting a Concours up on the stand daily, the VFR is a peice of cake.
    It's not a job for your back. It's all about the foot and the grab rail. On the 4th gen, you have to keep your leg back a bit or the foot peg will get your shin. Forces you to squre up and place your body correctly.
    Something no one has mentioned yet. you want to face the side of the bike with your body. Not forward or back. You put the ball of your foot on the lever and now you can feel the balance point as you stand the bike up vertically. Then press down on the lever while pulling up on the passenger rail. the left hand is on the bar to keep it from turning, not to lift or pull.
    Very easy to do, I almost never use my sidestand, just the centerstand.
  7. nozzle
    nozzle New Member
    Southern Maryland
    That is because his wallet was soooo light after buying the LT that he didn't have enough weight to lever it up. :tongue:
    no, it is the chain lube that allows you to rotate like that without scratching. I'm too afraid of having my VFR stuck on it's center stand for four or more hours (like the warning in the commercial) to ever try that stuff. :wink:
  8. whiteboyslo
    whiteboyslo New Member
    San Diego, CA
    any advice for a good method to get it up there if you have removed the passenger grab handles?
    Mike
  9. nozzle
    nozzle New Member
    Southern Maryland
    Have the passenger reduce exercise, eat fast food, and drink more beer. Although not a passenger, I'm proof that the handles will grow back quickly even if they were removed a few years back.
    note: Regardless of what the manual says, Grabbing the shaft above the passenger's footpeg is bad form, unless the person who is attempting to get it up has been properly introduced.
  10. whiteboyslo
    San Diego, CA
    ZING!!!!
    lol
    Mike
  11. sloan
    sloan New Member
    NW Houston, TX
    Grab the assembly that the passenger footpeg is attached to. I think that's what the book says on an '06.
  12. reg71
    Sikeston, MO
    I put my right hand under the subframe/tail section just under where it would be...or you can grab the rear footpeg bracket like the others say. The force is coming mostly from the foot anyway so the lift force doesn't have to be huge.
  13. KC-10 FE
    KC-10 FE New Member
    You shouldn't be touching the passenger handle at all. The correct way to use the center stand is to:
    push stand down to the floor with RIGHT foot
    grab left hand grip with LEFT hand
    feel for the exposed frame rail (this is the only reason this part of the cowling exposes the frame rail) under the rear cowling with LEFT hand (don't grab the plastic or you'll break the cowling)
    stand the bike up until you feel the opposite side of the center stand touch the floor
    once the bike is upright & level, push down with your RIGHT foot & pull straight up with your RIGHT hand
    the bike should pop right up with very little effort
    If you are pulling back, rocking the bike, jumping up & down on the center stand or need help, you're not doing right. I can put my bike on the center stand without touching the hand grips. Don't they teach this anymore?
    KC-10 FE Out...
    :plane:
  14. derstuka
    San Diego, CA
    I am not making fun of people at all, but just really find it interesting about getting the bike up on the sidestand. Personally, I have never had a problem, or even think about it. It is like tying my shoes. Maybe it is because I used to put my brothers FJ on the center stand when I was like 13 and I have it in my blood now. I think a part of the problem is probably what I initially felt...FEAR....fear of dropping the bike that is. Now watch, I have never had a problem, but know that I said it, I will probably drop the bike tomorrow.
    Reminds me, I still need to get that centerstand bolt out or rethreaded....I really don't feel like pulling the panels and full exhaust off just to get the bolt out.
  15. Nungboy
    Nungboy New Member
    Tucson, AZ
    Thanks KC-10...that helps.
    I know what Stuka is saying, like any skill, before you have it down, it seems very hard (and fear is always the big obstacle), BUT after you have learned it, one wonders why it was ever an issue. Learning some Mountain bike skills, or learning a certain drum pattern is that way for me...hell when I cannot quite get it and them embarassingly simple once the skill is learned. What is cool here is that no one is being put down or being smug about it learning this skill long ago. Well done, mates!
    Stuka learned to get it up when he was only 13...hmmm... :wink:
  16. drewl
    drewl Insider
    Virginia Beach, Va
    If the grab handles are gone( like mine) just lift under the fairing where the passenger foot peg is mounted...otherwise it is the same process and just as easy.
  17. derstuka
    San Diego, CA
    How you been Nung? You should have made the 900 mile journey to Reg's BBQ...lol.
    That is true with a lot of things, once we learn them, we wonder why we ever had trouble. I used to freak out at this gnarly ravine with a stream at the bottom years ago while mtn biking, then once I did it, I wondered why I ever had a problem for something so easy to me now.
