HF battery tender $9.99
Discussion in 'Mechanics Garage' started by RobVG, Mar 10, 2020.
  1. RobVG
    RobVG Member
    Seattle
    Bought this charger because my other one is on my 700- 80 miles away in storage.
    The battery was at 11.7 volts. The manual says don't use it if under 12v but I figured it was close enough. Left it connected for two days. After that, the battery was at 12.7v and the VFR fired right up after sitting all winter.
    https://www.harborfreight.com/automatic-battery-float-charger-42292.html
  2. VFR4Lee
    VFR4Lee Member
    Reseda / LA
    Yep, works and is a good deal.
    The only thing I don't like is it does not have ring connectors to attach to your battery.
    So you have to take off the seat and use the clamps.
    Boo hoo hoo. :High5:
  3. bk94si
    bk94si Member
    I stick with real Battery Tenders since a cheap one I bought long time ago fried my battery.
    Battery Tender Jrs are pretty inexpensive.
  4. KarlR
    KarlR New Member
    Esopus, NY
    Battery Tender is great. I have a 4x on the wall. Not cheep but your bike, mower, tractor, car will start, and the battery will last longer. I got 10 years out of my Victory battery.
  5. dbuzz77
    dbuzz77 New Member
    South Lake, Saskatchewan
    i use these on both my bikes and my truck. on the bikes i bought a 2 pin trailer connector and wired them to the bike batteries so i just plug it in.
  6. RobVG
    RobVG Member
    Seattle
    The seat isn't bad to take off ( mine requires a yank) but the battery cover- it's easy to lose the nut and bolt. Think ill put together some quick disconnects
