Honda VFR Caliper Mounting Boot Seal
Discussion in 'Mechanics Garage' started by Ottocle, Oct 29, 2015.
  1. Ottocle
    Ottocle New Member
    I have been replacing my brake pads on my 2001 Honda VFR 800. When attempting to remove the front right caliber I mistakingly removed the Mounting Boot Seal. How important is this part in ensuring the brakes function correctly? Can I replace it?
  2. rjgti
    rjgti New Member
    regina sk
    you do have to replace it
  3. Ottocle
    Ottocle New Member
    The seal or the whole caliper?
  4. squirrelman
    Replace the seal or the slider pins will rust and impede caliper movement. When replacing pads it's proper to clean and regrease the 2 slider pins on each caliper or they'll surely come a cropper and have you howling at the moon !
  5. rjgti
    rjgti New Member
    regina sk
    what squirrelman said ^^^
  6. Ottocle
    Ottocle New Member
    Thanks. How do I install it correctly? Not knowing was how I damaged the original one.
  7. rjgti
    rjgti New Member
    regina sk
    I lube it with dish soap and work it into place with a small screwdriver
  8. nearfreezing
    nearfreezing New Member
    Worcester, MA
    It should be easy to install back (look at the other caliper for a comparison), but if it's too hardened you can get another one cheaply.
