how do I rewind mileage?
Discussion in '1st & 2nd Generation 1983-1989' started by VFRUK, Mar 26, 2009.
  1. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    Just go to one of your local used car dealers and ask them how they do it.
  2. _oxygen_
    _oxygen_ New Member
    Cary, NC
    When I replaced the gauge cluster on my bike I just removed the old speedo from the housing and put it in the case. My housing was all busted up but the gauge worked fine.
    Oxygen
  3. midias
    midias New Member
    Rochester NY
    Yea well they got so heavy in the more recent years so honda thought they would need a reverse goldwing style. :thumbsup:
  4. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    Best suggestion so far.
    You can't just "roll the tumblers" unless you're a Swiss watchmaker. The parts are housed in a stamped steel frame that is peened together(you'll know what I mean when you take the gauge out); it would be very difficult and time consuming to accomplish.
    I only know this because I took my gauges apart to switch the bulbs over to LEDs... :ninja:
  5. reg71
    Sikeston, MO
    back to the drill thing... what about running it forward? Isn't the speedo rolled over at 100,000 on the old ones? And my second question, does the mileage go forward if the bike is off the ground and the rear wheel is turning? If so you could do the 'Ferris Bueller Method' in forward rather than reverse. If not, I'd just ride the bike a whole lot, then when you cross 100000 it'll look like it has way less miles and you'll have to tell people no it actually has more than that... I don't think I'd risk breaking all the little parts inside the gauges, but that's more due to my hamfisted nature.
  6. betarace
    betarace New Member
    Middleburg, VA
  7. Longerfellow
    Longerfellow New Member
    Pollock Pines, CA
    I did that once and melted the cable outer. More lube may have helped but...
  8. SPYKER
    SPYKER New Member
    MIDDELBURG, RSA
    I once tried a drill too, in two days the drill (Bosch, expensive!) was dead, the bushes totally worn out. and it only reversed about 4000km. Eventually dissembled the speedo, opened the dial and managed to reset it. one must be careful though, if you let something slip or assemble incorrectly- problems... Be sober when you do it :)
  9. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    That's got to be a record for oldest thread resurrection.
  10. Outboard John
    Outboard John New Member
    Escondido, Ca.
    Nope!!!!!
  11. jeremyr62
    Ireland
    Limerick, Ireland
    Nearly 8 years. What's the record then?
  12. Nelix
    Nelix New Member
    Paisley
    Pretty sure Stephen King answered this for the OP when he wrote Christine.
