How do you guys lift/work on your bikes?
Discussion in 'Mechanics Garage' started by Hellapet, Aug 11, 2016.
  1. Hellapet
    Hellapet New Member
    Media, PA
    good information guys. was thinking of trying the harbor freight jack but now i'm not! been burnt by so many of their tools...
  2. Boosh63
    Boosh63 Member
    Timmins, Ontario, Canada
    Don't do this....although I'm doing it as we speak.
  3. speed
    speed New Member
    Harbor Oregon 97415
    My luck we would have a earthquake
  4. Allyance
    Allyance Insider
    Germany
    East Bay, California
    Want to get a shock, go to http://earthquaketrack.com , set it for your location. We have had 588 earthquakes so far this year!
  5. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    The front wheel stop on the HF table is pretty worthless, but you can pick up their cheapo locking chock and bolt it to the table and you're good to go. As far as the table being an inconvenience, there's a reason you won't find a motorcycle shop without some kind of lifting table. If you've had to do much work on a bike you'd no longer look at them as an inconvenience. I wouldn't be without mine.
  6. speed
    speed New Member
    Harbor Oregon 97415
    Probably more than that. I have two earthquake apps on my phone, i had to set them to no Notification, it would wake me up all night.
  7. RotaryRocketeer
    RotaryRocketeer New Member
    OKC Metro, OK
    Undoubtedly (although not for 2nd gens.) Dude has an old-school VF though. If I'm not mistaken.
  8. OOTV
    OOTV Member
    Yep, good catch.
  9. sunofwolf
    sunofwolf New Member
    P1010195.jpg P1010088.jpg 001177_542 (54).jpg Mines the best-because I made it work
  10. OOTV
    OOTV Member
  11. ridervfr
    DSC02660.jpg IMG_20130531_112507.jpg Handy-Lift and a Lockhart single sided swing arm stand.
  12. Hellapet
    Hellapet New Member
    Media, PA
    good stuff, wish that ABBA lift had vf adapters. but it's probably out of my price range anyway. Thanks guys.
  13. RotaryRocketeer
    OKC Metro, OK
    The dude in the 3rd pic must be the muscle.
  14. 34468 Randy
    Is that an old photo or has the view not changed since early July?
  15. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Haha. Hasn't changed much with all my traveling and separation.
    Sent from my SM-G930W8 using Tapatalk
  16. 34468 Randy
    I bought an ATV lift a few years ago to work on mine. It sucks big time for working on our bikes. But I do make good use of it for other reasons. The bike is far too unstable sitting on that lift. If you were to put any type of force on a stiff bolt while up on that type of lift, it would likely topple over. Also, the lift contacts the underside of the farings so you risk damaging the plastics.
    I was going to get one of those platform motorcycle lifts from Harbour Freight but after reading some comments here, maybe I should re-think that idea. I was impressed with Jeff's lift though. Some day when I get a raise in my welfare maybe.
  17. James Bond
    James Bond Member
    Dixie
    Pit bull.
  18. sunofwolf
    I don't remove rear wheel, I would use the center stand if I really had too. I use my setup to change oil-works perfect for that.
  19. speed
    speed New Member
    Harbor Oregon 97415
    Im screwed, i threw my center stand away, i kept feeding it drag in corners,
  20. squirrelman
    On my gen 2's I've got a method that works fine. Use the scissors jack under the mounts for centerstand, and lift the rear wheel 4-5". Then set the stand, wood blocks, cinder block or whatever under the engine toward the front. When you lower the jack so the rear wheel is about 2-3" off the floor, the front end will rise, and both wheels will be up !!
    Do your heavy un-torquing before the bike goes up, and lean the bike very slightly toward a wall or find something to strap the frame to.
